Quantcast Audio Codecs: YUV 4:2:2 Codec - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Audio Conversion
08-17-2003, 05:43 AM
Jellygoose Jellygoose is offline
Hi there...
Well I just noticed, when I select YUV 4:2:2 in DVD2AVI as output for previewing, I only get a black picture... Is that normal?
Is there a special YUV 4:2:2 Codec besides msyuv.dll ?
__________________
j3llyG0053
Site Staff / Ad Manager
08-17-2003, 06:23 AM
Anonymous Anonymous is offline
What is the version you are using
I get the same result when using OGO version for instance, but with 1.7.6 it works fine.
08-17-2003, 10:40 AM
vhelp vhelp is offline
Hi Jellygoose..
That's my problem too !!
On my second PC that is. That one i have setup specifically for Capturing
and Encoding.
However, on my MAIN pc, I see BOTH colors. There IS a difference in each
* The RGB is Darker, while
* the YUV 4:2:2 is much lighter then the RGB (case you were curious)
All this on my MAIN pc only.
So, I must have the same issue you are having. Which codec ?? and how
do I install, etc. ??
-vhelp
08-20-2003, 05:16 AM
Well I tried version 1.7.6 and 1.77c and both have the same problem...
Well sorry vhelp, I really don't know what's going on... I'll just try it out with RGB, and see how the results come out...
__________________
j3llyG0053
08-20-2003, 05:40 AM
__________________
j3llyG0053
Audio Codecs: WAV Codec? muhali3 Audio Conversion 1 11-27-2003 04:35 AM
Codecs: BEST CODEC to use? Wak10 Video Encoding and Conversion 2 09-25-2003 06:22 AM
Audio Codecs: Ac3 codec J-Wo Audio Conversion 4 09-19-2003 09:54 AM
Audio Codecs: Best Audio Codec? Encoder Master Audio Conversion 7 08-15-2003 06:24 PM
Codecs: DXMan Video/Audio Codec Tool Bud Video Encoding and Conversion 1 08-13-2003 02:50 PM
All times are GMT -5. The time now is 05:35 AM  —  vBulletin © Jelsoft Enterprises Ltd
