Quantcast DVRs: Panasonic DMR-E50 Plays VCDs? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Hardware and Technology Forums > Players, DVRs, Media Centers
11-11-2003, 03:35 PM
ARAGORN ARAGORN is offline
Hi
I would like to know if this recorder plays kvcd.
Thanks in advance
ARAGORN
Site Staff / Ad Manager
11-11-2003, 04:06 PM
kwag kwag is offline
Originally Posted by ARAGORN
Hi
Thanks in advance
ARAGORN
The DMR-E20 and the DMR-E80 do.
I've tested all KVCDs (MPEG-1), and they work great.
They don't play S(K)VCDs (MPEG-2)
I think they do play MPEG-2 if burned as VCD, but not burned as SVCD.
I assume the E50 will, because they all share basically the same decoding circuitry.
-kwag
11-11-2003, 04:16 PM
Hi Kwag
Thanks for your answer. That's good news
I've seen your sample about your capture test with dmr 20
It seems good for the 6 hour mode
Have you tried to capture from a vhs? Does it clean the video?
ARAGORN
11-12-2003, 01:22 AM
You bet
And the DVD created from the VHS looks MUCH better
That's one of the selling points about the DMR series. Because of the internal TBC ( Time Base Corrector ) and built-in filters, you don't see any VHS head jitter on the created DVD.
It's really an amazing machine
-kwag
11-12-2003, 03:01 AM
Hi Kwag
All of this seems very interisting
I will buy this fantastic machine!
Thanks Kwag
ARAGORN
12-28-2003, 01:27 PM
Hi
I've bought it!!
Now, i've got tv shows that i've put on pc. I would like to make a dvdr with. What kind of script can i use to keep the same or near quality than the tv?
12-28-2003, 02:13 PM
Hi
I've bought it!!
Do you mean movies that you have on your PC
How are you going to get them out of your PC and record them to the DMR
Did I understand that correctly
If that's the case, you'll have to "playback" your movie in your PC with a card that has S-Video of Composite video output, so you can record the video in the DMR
-kwag
12-28-2003, 02:29 PM
Hi kwag
No. I've recorded tv shows with my dmre50 and I've put them on pc. Now i want to encode them with tmpgenc to make kdvd. What script should i use?
12-28-2003, 03:46 PM
Hi kwag
Ok
The MA script
But if your shows are telecined, you should use Telecide() and Decimate() to bring back the original frame rate ( Inverse Telecine).
If they are 29.97fps Interlaced, then check the "convert60ito24p" script.
If you are PAL, that's another story
Edit: Seems you are in NTSC land
-kwag
01-12-2004, 03:51 PM
el_mero_zooter el_mero_zooter is offline
Send a message via MSN to el_mero_zooter
Hi Kwag
Thanks Kwag
ARAGORN
So,
Ara
How's the machine working out for ya?
I bought one of these units and just got delivered over the weekend.
just barely hooked it up...and im dying to get some old vhs tapes recorded onto dvdram and kvcd'ing them or kdvd'ing them....
Seems very promising. Next year it'd be nice to upgrade to a unit with a harddrive though.
Zooter
DVRs: Orb Dano Players, DVRs, Media Centers 1 09-23-2005 07:06 PM
DVRs: Panasonic DMR DVD recorders Bud Video Capturing / Recording 3 11-12-2004 01:08 AM
DVRs: My next project! kwag Players, DVRs, Media Centers 18 11-06-2003 08:05 AM
Ps2 for VCDs? ijustbunkeredyou Players, DVRs, Media Centers 4 09-14-2003 04:39 PM
my dvd player only plays vcds? venom_217 Players, DVRs, Media Centers 1 05-08-2003 02:01 AM
All times are GMT -5. The time now is 10:35 PM  —  vBulletin © Jelsoft Enterprises Ltd
