03-04-2013, 03:38 AM
naripeddi naripeddi is offline
I have a digital Panasonic Mini DV Camcorder (Standard Definition) (NTSC). When I tried to play some of the recorded MiniDV tapes (which were recorded on the same camcorder), some of the tapes play well, but some do not play at all. I see a blank blue screen on Camcorder LCD, and I can also see it is not picking up the timecode data from the tape. The capturing program WinDV doesn't see any signal incoming. I am trying to capture the tapes using Firewire and store on HDD before the tapes deteriorate.
What could be the problem?
03-04-2013, 07:47 AM
thecoalman thecoalman is offline
Were they recorded using long play?
03-04-2013, 09:34 PM
No. Each tape has a maximum of 1 hour. Some of them are SONY cassettes and some are Panasonic. The camcorder is Panasonic.
03-05-2013, 07:35 AM
Other than that I'm not sure what to tell you other that try a different camcorder.
Is it just one brand you're having an issue with or both?
03-05-2013, 10:37 PM
Both Sony and Panasonic tapes are having this issue. I gave them to a transfer guy who reported that he was also unable to play them. The trouble is, it is NTSC camcorder which I bought while I was in the USA, but I am in PAL land primarily. So cannot really find another NTSC camcorder to test out.
May be I will assume the tapes have gone bad or something.
My Betamax video tapes go blank while playing? Nayls Capture, Record, Transfer 2 02-08-2013 08:54 AM
Strange "Blue Screen" Quirk With Samsung SV5000W... farsythe Video Hardware Repair 4 05-07-2012 03:42 AM
Very odd VHS tape recording mystery, red/blue color bands on screen jimvhs Capture, Record, Transfer 6 09-17-2011 11:51 PM
JVC SR-VS10 Eats MiniDV Tapes - Help? jbd5010 Capture, Record, Transfer 3 02-10-2011 07:33 AM
