Go Back    Forum > Digital Photography > Photo Cameras: Buying & Shooting
04-11-2018, 04:18 AM
mBrands mBrands is offline
i have running a small online shopping site. i have low SEO and the big issue is there is big images.. i want to ask how can i minimize the images from my website
04-12-2018, 01:24 AM
ehbowen ehbowen is offline
Have you tried resizing them with IrfanView (it's free) and then using its "Save for Web" plugin? Works like a charm.
04-13-2018, 03:28 PM
nick08 nick08 is offline
Hi m Brands,
There are many. You can use server based scripts if you want to minimize all images in bulk. Else you can use any online lossy compression tool to reduce image size manually and re upload them on your website.
04-13-2018, 08:27 PM
Freeware like Gimp does "save for web", which compresses down as much as possible.
As does aforementioned freeware IrfanView.
I've used the popular payware Adobe Photoshop since the early 90s, and it's had a "save for web" function since the early days of web (either 5.0, 5.5, or 6.0, I forget, around 1995 or so). At least 20 years now.
You also need to remember to resize the image. Not a huge MP image direct from a camera, but something around 1000 pixels max.
The following users thank kpmedia for this useful post: archivarious (01-15-2021)
images, minimize, online shopping
How to minimize pixelation when converting AVI to MPEG? Slider Encode, Convert for discs 5 02-08-2018 08:28 PM
Mitsubishi HS-U80 S-VHS VCR (1988) sample images! Tasuke Capture, Record, Transfer 7 12-14-2014 11:34 AM
New before/after images bbcode for forum admin General Discussion 3 12-18-2011 07:15 AM
Scanning with ICE vs no ICE [Sample Images] kpmedia Photo Processing, Scanning & Printing 11 03-25-2010 07:33 PM
Jittery/choppy images w/ old VHS Triassical Capture, Record, Transfer 3 11-13-2004 06:13 PM
