Quantcast Photoshop Question, how to merge photos into trio panel ? - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Photography > Photo Processing, Scanning & Printing
03-19-2009, 10:06 PM
Canon Canon is offline
How do you open three photos. Make them the same size and then "glue" them together to make one image that is three different frames like the following example.
http://www.flickr.com/photos/10751420@N07/2887026660/
11-25-2011, 09:50 PM
Site Staff / Owner and Editor
This member was banned before the question was answered. In the interest of not having unanswered questions on the forum...
Step 1: Create a new master image (File > New), with a canvas of desired size, with a black background.
Step 2: Copy each photo into a new layer on this new canvas. (CTRL+A on the image to select, go to new image, CTRL+V to paste. Substitute CTRL for APPLE on Macs.)
Step 3: Use the Free Transform filter (Edit > Free Transform) on each layer, resize as needed.
Step 4: You can merge the individual image layers by holding CTRL and selecting each photo layer (but not the background), then using CTRL+E to merge the layers. Then use the "dotted box" selection tool (I forget the name of it) to clean up the edges of the now-single resized photos layer, and create a smooth/clean identical edge for all images by deleting the outer edges. You'll be selecting the part of the image you DO NOT want to keep (the background will stay), and deleting it. If this step doesn't make sense, simply reply to the post, and some images can be provided to expanded this mini-guide post. This can be done in several ways, including using square brushes or layer-based crop with guides, but I tend to take the path of least resistance.
Easy and basic task here.
__________________
- Thanks for visiting! | Advertise on The Digital FAQ | Upgrade to Premium Member
flickr photoshop
Kloxo control panel review, do you use it and what do you think of it? kpmedia Web/Print Publishing Technology 0 07-11-2011 09:11 PM
CPanel 'switch accounts' menu disappears, refreshes to client panel [FIXED] kpmedia Web/Print Publishing Technology 0 02-13-2011 07:52 PM
Here are some of my photos for critique Sossity Making the Shot 4 08-04-2010 11:28 PM
Processing photos in Photoshop segen77 Photo Processing, Scanning & Printing 5 11-05-2009 08:08 PM
Software to get photos off Canon 20D ?? admin Photo Processing, Scanning & Printing 0 09-25-2009 04:01 PM
All times are GMT -5. The time now is 08:24 AM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
