01-27-2020, 08:45 AM
flyingduck flyingduck is offline
Hello everyone. I just got a FREE panasonic Palmcorder as described in title. It is in great shape but it has an issue and I don't know what to do to fix it or if it can be fixed. I transfer taped movies/videos to DVD and will use the camera to play VHS-C tapes into a DVD burner.
ISSUE: When I put the tape in the tape box closes. I get a continous clicking sound, the power light goes off and on and the tape moves forward a little bit then rewinds itself. If I look into the viewfinder while in the camera/record mode I see what would be recorded for a second or two. The screen goes blank and then the picture comes back on for a second or two and this just keeps cycling on and off.
Can this be fixed or do I need to make this camera a boat anchor?????
01-27-2020, 02:22 PM
The question should be can you fix it? not can it be fixed? If you are not familiar with such high precision complicated electro-mechanical devices my suggestion to you is put it where it belongs, the trash can because it is not going to work as a boat anchor.
01-27-2020, 02:32 PM
Well, I was hoping for at least a sympathetic answer! Maybe someone else has had the same or similar issue and could shed some light on what the problem might be. I don't mind taking the camera apart if there is something that I can do. I like tinkering with such things and have fixed camera issues before.
Panasonic AG-1970 screen turns black? Chickensalad39 Video Hardware Repair 20 12-14-2018 09:28 AM
Clicking noises from mono VHS, static electricity? Koen Video Hardware Repair 15 05-05-2017 10:42 PM
MiniDV Tapes not playing - blank blue screen? naripeddi Videography: Cameras, TVs and Players 4 03-05-2013 10:37 PM
Auto double-clicking Mouse Problem bigk181 Computers 11 09-29-2012 04:26 AM
JVC DR-MX1S DVD recorder makes clicking noise, help! JDiane Video Hardware Repair 3 12-28-2011 05:24 AM
