11-28-2020, 11:06 AM
Nehalem_i7 Nehalem_i7 is offline
Do you need a battery to use the GX7 or can you just use a AC adapter to power the GX7
the manual says to plug the AC adapter directly from mains to camcorder
but i cant see any connection on the back of the camcorder to connect the AC adapter to.
11-28-2020, 02:42 PM
The AC adapter connects in the battery slot. It's like a very flat battery with a wire that connects to the power brick. as you can see on the illustration.
11-29-2020, 06:52 AM
i bought GX7 without a charger batteries or accessories would a AC adapter be suffice, do i need to connect something else to the back of the GX7 to use AC adapter, as the ones ive seen dont look like they are the right ones
11-29-2020, 09:25 AM
You would need an adapter that comes with this thing (image from a long gone ebay ad):
The battery-looking part connects to the camcorder battery slot, while the barrel plug connects to the battery charger. Part number seems to be k2gj2dz00011 according to the manual.
Rather than having a AC input plug on the camcorder, they used a dongle that connected to the the battery slot instead. It was a common method of providing power from AC on older camcorders.
If you are very adventurous and cant find an adapter you could maybe jerry-rig something that connects to the battery terminals on the camcorder with the right DC voltage.
11-29-2020, 09:47 AM
thanks for the help for the price of the k2gj2dz00011 its much cheaper to buy a battery and usb charger both for £15
APC backup battery finally died, what next? rocko Computers 5 01-09-2018 07:31 AM
Questions battery AA and AAA and battery charger gamemaniaco Digital Devices 0 03-15-2017 07:03 AM
Static charge on DVD media? redbolter Blank Media 1 04-26-2016 05:32 AM
What to charge for SignVideo equipment, TBC ? Junior1s General Discussion 6 02-21-2013 11:23 AM
How to charge a laptop battery? Superstar Computers 1 01-24-2011 08:46 PM
