09-25-2009, 02:21 AM
Johnbear Johnbear is offline
NOTE: This post has been edited, because the person who left it was a spammer. However, the device was interesting, so I've left parts of the post up. Most of it is Engrish, some Chinese person used translation software.
This is essentially a bootleg-and-upgraded version of the Sony PSP.
-admin
In an age that HD MP4 takes most of the market share, the two manufacturers Gemei and Angda work together, and promote a new type of MP4---Geda VX690HD. The resolving power of the 4.3inch screen is 1920*1080 which is superior to the HD MP4 in the market. The appearance of this MP4 is designed by the engineers, which breaks the situation that all the MP4 are the same. The thing should be paid special attention to is Geda VX690HD can play the 1080P-wide format video. Even if the code stream reaches 100Mbs, it can cope with it smoothly, which really can be called to play it without conversion. This capability is what RMVB box has.
Geda VX690HD can read the HD DVD and blue ray DVD (Mini Disc), which solves the problem of the disc source. The good capability of the player comes from the excellent processor core. Geda VX690HD adopts the CCAV5400 chips of Chip China Rock. According to the president of Chip China Rock, the comprehensive ability of this chip is above the AMD5400+, here comes the name 5400. Actually, this is a little modest. The ability of this chip is the same as or stronger than the Intel Core 2 Extreme QX9770. But what does CCAV mean? I don’t know as well.
Some people say that there is something wrong with the HD of the VX690HD; they say it is not the solid-state HD. If you are serious, you will fail. There should be some explain. The solid-state HD that VX690HD uses is not the common SSD HD, but SHDD HD. The storage media of the SSD HD is flash memory, while the SHDD HD uses one or more Aluminum or glass disc the same as the HDD HD. The operation process of the HDD HD is the rotation of the disc, and the movement of the magnetic head is very small. As for the operation process of the SHDD HD, the disc is static compared with the HD, and it is the magnetic head moves. Therefore, it is named as solid-state HD. The HD that adopts the SHDD technology increases the HD’s shock resistance due to the irritation of the disc. Meanwhile, because the disc doesn’t rotate, the atom in it will not move due to the centripetal force. Therefore, the SHDD technology takes or put down the atom from the disc by the magnetic head. The place that the atom has been taken is scanned will form a low voltage, which is numbered as 0 in the computer language, and the place with no space is numbered as 1. Theoretically speaking, if one atom that has been taken is a data, then a disc can store a large number of data. But the SHDD technology is not that mature at present, it can only take 10^5 atoms at one time. Therefore, the memory space of VX690HD’s HD has only 4TB capacity.
10-01-2009, 04:27 AM
Above post has been de-spammed and edited.
Interesting item, runs Windows XP on a PSP close-like device.
