08-25-2011, 10:51 PM
jrodefeld jrodefeld is offline
Hello,
I am in the process of capturing VHS home movies with Huffyuv AVI. Then I am processing them with Virtualdub filters (as necessary). The encoding software I will be using is MainConcept Reference. What I want to know is what settings I should use to obtain the highest quality encodes from VHS sources. There are MANY settings and options and I don't know what many of them do. I am using Double Layer DVDs.
What are the best settings to use in MainConcept Reference for VHS sources? Any help you could provide would be greatly appreciated.
08-26-2011, 11:27 PM
Could anyone help with this? I am sure that some of the settings would be dependent on the source, but I would think that for VHS sources there would be certain consistent settings and tips for getting the highest quality encodes, right?
08-27-2011, 07:42 PM
I'll need to know this first: Did you capture/restore as 720x480 or 352x480 video resolution?
08-29-2011, 03:53 AM
720x480. I didn't really think about it, but is there a reason to capture and restore at 352x480?
Thanks for your help.
08-30-2011, 01:29 AM
This is almost going to require writing a new guide. To speed this up for your situation, why don't we do it the other way around? Post some screen shots of your various MainConcept Reference encoding tabs/panels. And then I can tell you what is right/wrong, or could be tweaked. That should get it moving.
Thanks.
I've made note that a guide is needed, but it's honestly going to be a little while. Backed up right now, well into September.
Trouble opening Mainconcept file unclescoob Encode, Convert for discs 9 09-18-2011 06:08 AM
Help using MainConcept 1.5 Encoder lordsmurf Encode, Convert for discs 56 07-07-2009 11:45 PM
Mainconcept or procoder or else what? manthing Encode, Convert for discs 1 04-05-2008 07:28 AM
Wanted: settings for mainconcept for AP wigam Encode, Convert for discs 4 09-05-2005 04:55 AM
