04-15-2017, 09:37 AM
The service manual has nothing for this.
Does anybody here know how to remove the pinch roller arm assembly?
The SR-V10 uses the same transport as the HR-S5900 and 3900, as well as some of the other Professional Series decks. The 5900 manual shows how to do it (though not well), but the SR-V10 and 101 appears to have different transports (therefore different pinch arm assemblies).
04-17-2017, 01:36 PM
Quasipal Quasipal is offline
Is it not a simple circlip or split washer? Sometimes you can change the roller without removing the arm - is the old one perished?
04-20-2017, 12:01 AM
It was a plastic clip. I'd never seen a roller like this before. It was inverse to most JVCs. You have to get a tiny flathead and pry it apart. The piece is cheap plastic, and will not last too many removals.
Now I'm having this problem: http://www.digitalfaq.com/forum/vcr-...v101-vcrs.html
Replacing the roller didn't help much.
Panasonic NV-HS 1000 pinch roller issue? Sparx Video Hardware Repair 14 12-26-2015 09:01 AM
How VCR pinch rollers work! [FAQ] Quasipal Video Hardware Repair 3 05-08-2015 10:25 PM
How to change pinch roller on Panasonic NV-HS1000? Mejnour Video Hardware Repair 2 01-04-2015 11:11 AM
JVC HR-S6800U eating tapes, roller guide issues Jpass992 Video Hardware Repair 1 08-12-2014 12:38 AM
JVC SR V101US to fix or not to fix? Jpass992 Capture, Record, Transfer 12 06-18-2012 07:30 PM
