07-10-2017, 08:04 PM
tj0007 tj0007 is offline
Hi!
I am making a documentary about a particular 1980's rock group
and one of my collaborators - in the UK - has a 1983 master live recording
which is on, I am told, 2" NTSC tape. It's not a format I can find much info about.
It's somewhere between 70 and 100 minutes long.
I am guessing that the tape will need to be sent to the US, which is fine,
but I need some advice about where specifically we should send it to.
Hope you can help!
Cheers
Ben
07-10-2017, 08:24 PM
Are you sure it's 2"?
Quadruplex videotape (Ampex) seems unlikely.
I'd be more inclined to believe it's D-2. That'd make much more sense.
Measure the tape width. Confirm it really is 2" in size.
07-10-2017, 08:29 PM
Thanks - I have just sent my friend an email and I will advise you what I learn ASAP.
07-11-2017, 06:42 PM
NJRoadfan NJRoadfan is online now
If it is open reel and 2 inch wide tape, its almost certainly quad. The D-2 cassette standard didn't appear until the late 80s, so that's out (unless it was a dub, not a master). 1 inch open reel would be standard for the time, likely Type B or C. The dominant cassette format at the time was still 3/4" U-Matic with Betacam having just appeared on the market.
PAL tape conversion to NTSC Mejnour Project Planning, Workflows 9 06-23-2015 04:44 PM
Novice Seeking DVD Creation Advice jolafson Project Planning, Workflows 2 12-07-2013 10:39 PM
Seeking Advice on Matrox MX02 Jarvis Capture, Record, Transfer 11 04-12-2013 02:50 AM
Seeking Guidance on VHS to digital conversion equipment and procedures... kaliree Project Planning, Workflows 6 02-22-2011 02:39 AM
Seeking advice on an audio equalizer robjv1 Capture, Record, Transfer 2 11-26-2010 07:53 PM
