09-04-2014, 03:39 PM
Zilog Jones Zilog Jones is offline
I bought this VCR on eBay a few years ago (back when this stuff was < €100, thankfully), and have never been too impressed by the picture quality.
One particular issue I noticed when recording this test video:
https://www.youtube.com/watch?v=ZLevxHUnaj0
In areas where there are solid vertical black and white bars they are often accompanied by horizontal noise (comet tails?). It's not seen as often with normal video/film content but does happen occasionally with bright high-contrast graphics.
Also this was played with the TBC on, but there's still a lot of jitter (if you play at 1080p you'll see the edges more clearly). Is this normal behaviour of the TBC in VCRs like this? This is consistent with how the TBC works with normal video content on this VCR.
I don't have a captured example, but S-VHS playback has constant snow (the same tapes play fine on my JVC HR-S7000EG) and is pretty much unusable.
I have tried cleaning the heads (with head cleaning sticks and IPA), but it hasn't made much difference. Is there anything else that could be at fault?
Even more disappointingly, it looks like replacement heads (VXP2050) are no longer available for this unit (I contacted Donberg and they are no longer able to source it), whereas they are for the HS950 and older decks.
Digital 8mm dirty heads; Use a cleaning tape? reddragon81088 Video Hardware Repair 13 07-27-2017 07:28 PM
JVC heads not spinning up? volksjager Video Hardware Repair 3 07-17-2013 10:27 PM
How to clean VCR heads on JVC HR-7600EK S-VHS deck? Hackerpcs Capture, Record, Transfer 2 07-19-2012 09:45 AM
Cleaning VCR heads proper methods? fuzzblaster Capture, Record, Transfer 1 08-31-2010 07:44 PM
VHS maintenance/cleaning - What problems do dirty heads cause? cyber-junkie Video Hardware Repair 5 02-12-2010 04:31 PM
