12-24-2015, 03:33 PM
I wanted to watch some old home movies recorded from this camcorder. When I plugged it into my tv though, the audio skipped every second. I checked using a different tape from a different brand and got the same problem. The head cleaner tape I had didn't help much. Since I doubt JVC supports this MiniDV camcorder anymore, got any suggestions on how to fix this issue other than "get a different camcorder, preferably from Sony"?
12-26-2015, 07:45 AM
Head cleaners are always useless.
You have a DV tape. Was it recorded LP or SP? And was it recorded on this same camera?
12-27-2015, 11:52 AM
Most of the tapes are SP. One of them is mostly SP but goes to LP at the end. The strange thing is, I played all the tapes a few weeks ago and they played back perfectly.
01-02-2016, 03:26 AM
That's not strange at all. That points to the camera more than anything. It has a fault. That often happens when an old VCR or camera has not been used for a while. It has one last good use in it before an issue became apparent -- usually something power/capacitor related. Welcome to video.
01-04-2016, 04:18 PM
So...what should I do about the camcorder? Is there a way to fix it, or would it be better (or cheaper) to flat out replace it?
01-05-2016, 09:15 AM
Try the tape in another camera to rule out the tape being at fault.
