01-14-2019, 12:51 AM
I owned this VCR for a while never had any problem with it, until recently I recorded some videos into a S-VHS tape in S-VHS PAL and noticed a noisy color stripe on the very top of the frame - See video below, Prior to this recording the VCR was plugged in as usual in standby mode for few months. Immediately started investigating the problem and did the following tests:
- I played back tapes that was recorded in this machine about a year ago, in both VHS and S-VHS, NTSC and PAL, No stripe.
- Played back pre recorded NTSC VHS/S-VHS tapes, no stripe.
- Recorded in NTSC from NTSC source in VHS and S-VHS, The stripe is there in playback.
- Recorded in PAL from PAL source in VHS and S-VHS, The stripe is there in playback.
So it's clearly a problem of the recording board. TBC/DNR on or off didn't matter.
Here is a video of the problem.
One of the recordings I did on it before is this, Note that the video is not cropped on the top.
I have the service manual but I don't know where to start from.
I probably should remove the main circuit board and inspect it for loose components or bad capacitors, These are easy to take a part anyway, After removing the face plate and the mechanism 6 screws the whole thing comes a part, I will get a chance to clean and lube the mechanism and inspect the dynamic drum gears for cracks. The record chroma board should be close to where the drum ribbon cable connects.
I figured it out on my own, The Chinese HDMI to S-Video adapter that I'm using is causing this color burst problems on the top of the fields, I tried recording from another source and the VCR recorded clean image. Now at least I know my VCR is not defective, ooof!
JVC HR-S7600AM keeps shutting down after 3 seconds? Blackout Video Hardware Repair 124 12-28-2021 01:55 PM
JVC HR-S7600AM Spare Drum Quest latreche34 Video Hardware Repair 0 05-05-2016 12:48 PM
JVC HR-S7600AM settings keep resetting? latreche34 General Discussion 2 03-02-2016 03:11 AM
Wanted Remote Control for JVC HR-S7600AM [FOUND] latreche34 Marketplace 1 02-13-2016 01:06 AM
Wanted: JVC HR-S7600AM VCR [FOUND] latreche34 Marketplace 1 01-26-2016 11:26 PM
