08-30-2019, 01:15 AM
dima dima is offline
1. Should the new pinch roller (unused) look like the pictures attached to the post ? Is it renovated or something ? Experienced experts should know that I think.
[Purchased as new. I know that the white dust that can be seen in the pictures should not be on it.] I ask for help if possible.
2. Is it whether and how the pinch roller presses the tape against its path matters for the quality of the displayed image ? Force with which tape tightens etc. ? [I know that e.g. a bad pinch roller can cause physical damage to the VHS tape - this is not the case I am talking about. I am talking about such a case, when everything is good in terms of the tape - without causing damage to it, and only, for example, the pinch roller pressure is too weak or at a slightly wrong angle(a wrong angle can cause a "bad tracking effect" surely - that's my guess. I think mainly about the downforce, but also about the angle) - example].
08-30-2019, 09:39 AM
josem84 josem84 is offline
The pinch roller looks ok to me. You know you have to change it when the surface becomes polished, loosing its ruberyness. A worn out pinch roller is the number 1 cause for tape curling.
Replacement of pinch roller in Philips VR20D? dima Video Hardware Repair 12 08-26-2019 01:13 AM
Transplanting pinch roller on Sony Hi8/D8 camera? hodgey Video Hardware Repair 1 09-16-2018 10:53 PM
How to remove SR-V101US pinch roller assembly? lordsmurf Video Hardware Repair 2 04-20-2017 12:01 AM
Panasonic NV-HS 1000 pinch roller issue? Sparx Video Hardware Repair 14 12-26-2015 09:01 AM
How to change pinch roller on Panasonic NV-HS1000? Mejnour Video Hardware Repair 2 01-04-2015 11:11 AM
