09-12-2019, 05:31 PM
digo_neves digo_neves is offline
Hello there, pals. I'm new to this forum, but I've been reading quite a lot to understand more of the process of capturing video, as I wanted to save some old footage that I have on VHS and Mini DV. I've recently purchased a second-hand Pinnacle 510 USB, and it has been of great help to capture my videos. I was having problems to get the S-video input to work, and I found the solution in this thread - which was using the small "Crossbar thing" tool.
But I have a different issue now; here it is: My Mini DV camera does not have an S-video out, but a P2 jack where I connect a P2 to RCA cable. I was able to find an RCA to S-Video converter, so I could transfer the videos through the S-video connector, and it worked - it was clear that the edges of things in general were sharper, and overlay texts looked far better than they did through the RCA jack, but some odd artifacts showed up - I'm not even sure this is how I should call them. They look a lot like some moirč artifacts. I have attached a video sample to better illustrate the situation, as well as a pic of the adapter I used. Though my camcorder has a firewire port - which is going to be used soon, I was also interested in solving this issue so I could do the same signal "separation" with my VHS-C camera. Thanks in advance if anyone is willing to help!
Details about the capture:
Camcorder: Samsung SC-D381;
A/V out using an RCA to S-Video adapter, so I can hook it up to the capture device through the S-video input;
Video captured through VirtualDub2 build 43702, originally using Lagarith lossless codec and compressed with XVid codec; deinterlaced using Yadiff, TFF.
-- moved from http://www.digitalFAQ.com/forum/vide...e-video-2.html
Last edited by lordsmurf; 11-25-2019 at 03:06 AM. Reason: Post moved to new thread.
09-14-2019, 11:39 AM
Artifacts are expected when passing a composite signal to an S-Video input via a passive electrical adapter like that.
For S-Video output of VHS-C, you must play back on a S-VHS VCR or S-VHS-C camcorder.
Best way for highest quality video from VHS, VHS-C, MiniDV? Ruby510 Project Planning, Workflows 6 12-20-2020 11:48 AM
Camera motor noise recorded on digital MiniDV tape? knumag Restore, Filter, Improve Quality 7 05-23-2014 01:32 PM
Is a MiniDV camera with 3CCD better than one without? DeeSeven Capture, Record, Transfer 7 05-13-2014 02:49 AM
For Sale: Redrock M2 Micro 35mm Canon Eos Camera Lens adapter+MicroX flip alinamorena35 Marketplace 1 09-25-2011 02:51 AM
