09-03-2020, 04:16 AM
nevs nevs is offline
Hi,
I have read this very useful guide at http://www.digitalfaq.com/forum/vide...-settings.html
I am capturing hi8/video 8 tapes as per details below in virtualdub and I have some questions:
Resolution: 720x576
PAL/NTSC: PAL
FPS: 25
Colour space compression: YUY2
Compression: Huffyuv V2.1.1
Questions for best quality:
Q1: YUY2 compression = Predict Median or Predict Left?
Q2: RGB Compression = Predict Gradient or Predict Left?
Once I have captured, and I start applying filters outside of capture mode in virtual dub etc
Q3: What should my video compression settings be for Huffyuv – I assume the same?
Q4: Video Colour depth – what should be set for “decompression format” and “output format to compressor”?
I believe the filters only work in RGB, so should I convert to RGB if doing filter work to avoid going from YUY2 to RGB over and over again loosing quality? Can I capture in RGB to start with?
Q5: Should “smart rendering” be on or off?
Thank you.
09-03-2020, 04:37 AM
Always YUV (YUY2, etc).
Never RGB.
Color depth always YUY2 for capture/VHS work.
Always keep lossless intermediary codecs during restoration, editing. Only compress down to MPEG or H264 on final output. I use both Huffyuv and Lagarith myself, depends on project software workflow in use.
Let the filters convert to/from RGB, don't try to help it. Master in/out is a YUV.
You can only smart render without filters. That's a no-reencode mode.
09-03-2020, 06:00 AM
Thank you for your help. Excuse my ignorance...
Therefore should I change colour depth from "automatic" to "YUY2" when editing to make sure nothing happens? or can I trust it under automatic?
In terms of quality:
09-03-2020, 06:02 AM
Never automatic. Computers are dumb tools, make mistakes (more than humans).
Leave Huffyuv on defaults.
The following users thank lordsmurf for this useful post: nevs (09-03-2020)
Restoring colour in VirtualDub on DV via WinDV? nevs Restore, Filter, Improve Quality 3 09-09-2020 06:23 AM
Best VirtualDub codecs for compression? nmaxfield Capture, Record, Transfer 7 12-15-2016 05:41 PM
VirtualDub settings, only outputs AVI file? Mejnour Encode, Convert for discs 3 02-17-2016 11:24 AM
VirtualDub - advice on the filter settings deter Restore, Filter, Improve Quality 7 01-21-2010 09:54 PM
