07-20-2020, 03:55 AM
Eric-Jan Eric-Jan is offline
Not being able to decide (for this player) which mode to go into could also be a "feature" of the S-VHS ET detection ?
playing these "faulty" tapes on another VHS vcr can determine that, other than long discussions about it
07-20-2020, 03:56 AM
Originally Posted by latreche34 View Post
According to his own thread the problem was dirty heads not tapes:
http://www.digitalfaq.com/forum/vcr-...html#post70165
then why is this thread started ?
08-25-2020, 11:44 AM
bakerie bakerie is offline
Panasonic NV-HS830 not playing tapes, noise, running slow?
Read more: http://www.digitalfaq.com/forum/vide...#ixzz6W9JE014L
Not to dig up old threads, but I just noticed I never replied to this and feel bad for leaving it.
There are tapes that this machine just can't play and it shows the S-VHS ET flag. There are tapes where I can get them to play by driving the tracking manually as far as it will go, when they aren't playing it shows the the S-VHS ET flag. When the heads where dirty and it wouldn't play anything, it was continually showing the S-VHS ET flag.
So either that flag just comes on when it can't lock to a standard, or there is an issue with this VCR that it defaults to S-VHS ET when it gets confused. It's over 10 years old, so I can't really fault it
I will say the automatic tracking on it is abysmal, I had to manually track nearly everything. (but again, old machine, caps could be dead in the tracking circuit)
Why AJA Kona LHi/LHe/LSe cards not VirtualDub compatible? Aerith Capture, Record, Transfer 38 03-21-2022 04:32 PM
Looking to digitalize VHS tapes from 1980s, need a player Jtm732 Capture, Record, Transfer 2 01-11-2018 08:26 AM
Best player for cheap tapes? FrostBite Capture, Record, Transfer 4 10-17-2015 04:14 AM
Looking for very good VHS player to convert tapes to DVD/AVI sesselmarder Capture, Record, Transfer 2 05-25-2012 11:26 PM
Panasonic AG 1980P S-VHS player ejects all tapes - help! admin Capture, Record, Transfer 0 09-01-2010 12:57 AM
