You can only get the teletext signal from a Super-VHS recording, on a Super-VHS cassette,
you can replay the Teletext on your Teletext able tv, decoding Teletext from the capture of that Super-VHS recording is an other story......
Found the same thing the others found with a Google search...
But what also should be mentioned......you need the Linux OS for it... i don't think anything will be available for the Micro$oft OS...
