01-09-2022, 07:35 AM
lollo2 lollo2 is offline
PAL VHS uses 702 pixels of the available frame size, DV might use all 720 pixels, but to maintain the correct 4:3 aspect ratio of the source the frame size should remain as 720x576 ?
No. Pal VHS captured frame is 720x576, but the active area is 702/704x576. The 4:3 aspect ratio refers to this last (search the latreche34 experiment on display a circle here or in videohelp forum).
Then you crop the original frame to 704x576 and encode with a 4:3 DAR. If you rebuild the 720x576 there is a small error. You can choose this last if you do not mind
The following users thank lollo2 for this useful post: London (01-24-2022)
01-24-2022, 05:06 PM
London London is offline
Thanks lollo2 for explaining this.
I read the post by latreche34 you mentioned and the posts linked within it. Thats is all clear now....analogue 4:3 when digitized has an active area 704x576.
I also noticed that satellite broadcasts of old TV shows in 4:3 here in the UK are sent at 704x576.
Clipped audio levels during capture with multiple hardware? ELinder Capture, Record, Transfer 28 02-05-2020 06:41 PM
Getting Capture Levels Right (Proc Amp Settings) ehbowen Capture, Record, Transfer 2 04-24-2019 09:45 PM
Capture whole tape with one set levels, or different levels per scene? stevevid Capture, Record, Transfer 5 08-22-2018 11:29 PM
Proper VirtualDub video levels for Tevion USB capture? Jtm732 Capture, Record, Transfer 3 02-08-2018 05:28 AM
Optimizing AIW proc amp levels for every capture kooz Capture, Record, Transfer 6 03-19-2017 10:34 PM
