02-02-2022, 01:22 AM
javidial javidial is offline
Hi,
After sometime I decided to put to good use my Panasonic NV-HS950 vcr (PAL), so I connected it through s-video to my Hauppauge USB-live2 capture card.
So far I can't get it work with virtualdub, but I was able to make it work with AmarRecTV, but the image flickers a lot.
Can somebody tell me if this is due to the lack of TBC or if the vcr is broken and need to be fixed?
Here I uploaded some small clips (next post). Maybe somebody has seen this before.
In a few days I'll received a DMR-ES15 to use as a TBC(ish). Will try to see if it gets better. If not, I'll assume the vcr is broken. Once I save more money I'll try to upgrade to a better capture card, but now I'm trying to figure out what's going on with my vcr.
Thanks again, any help will help me out a lot.
Hope this year I can upgrade the capture card to a proper one too.
video samples here
02-02-2022, 02:27 PM
Step 1 when troubleshooting something like this is always eliminating the computer side of things.
Connect it to a TV and see how it looks. Ideally a CRT, since flat panels need to internally convert to digital to display anything, but connecting it to any display will at least give you another data point.
02-02-2022, 02:32 PM
I'll try to get somehow a CRT tv if I find one, in the meantime I'll try to view it in my normal tv.
Something else that happens its that the audio captured has a minor delay L from R channel, so it sounds like reverb or duplicated. I tried capture with the motherboard as well with the usb capture card and both sounds like Alvin and the Chipmunks.
I tried plugging the vcr to a monitor. Also hooked a headphones directly to the rca in the vcr, and the sound is still with echo, like reverb / phasing issue I believe.
I think I should take the vcr to a repair shop
03-19-2022, 03:18 AM
That 610 card + lack of frame TBC may be issue here. A bit of both.
And/or perhaps the VCR.
Lots of variables at play here.
Those post was more than 1 month ago. Any progress made, or just waiting on some new gear to arrive?
03-19-2022, 10:00 AM
I should receive a new vcr any day and time I’ll post results in here.
VirtualDub Capture Preview - Video Flickering & Glitching rprilenski Capture, Record, Transfer 3 07-17-2021 11:37 AM
Color flickering on deinterlaced VHS capture? thunderbirds93 Restore, Filter, Improve Quality 6 02-22-2021 04:08 AM
VHS Capture Issue Ryelzz Capture, Record, Transfer 1 09-16-2019 10:25 AM
VHS capture with SDI issue cerestan Capture, Record, Transfer 6 10-12-2015 01:20 PM
Capture Dark/Bright Flickering godsfshrmn Capture, Record, Transfer 5 01-06-2010 11:32 AM
