05-10-2022, 05:48 AM
overdrive80 overdrive80 is offline
Hi all.
I gonna to digital vhs tapes. I had a vcr of my parents (Samsung with 6 headers and s-video output). I bought usb video card (UCEC video capture) but only got colorless images.
My system is new and I have not agp line and I use Win10, therefore Lord Smurf recommends (alternatives for AIW) Hauppauge 610 USB2 capture stick. In my country USB-Live2 Analog Video Digitizer.
Exists the option for PCI (Hauppauge Impact VCB - Internal Card TV (PCI))
After the preamble, which option would be the most recommended? PCI or USB?
Thanks in advance.
05-10-2022, 08:03 AM
"6 heads" is just marketing and the S-Video output probably isn't "real", for what it's worth. (Did Samsung make/rebadge S-VHS decks anywhere in the world?) It sounds like it's just a low-quality combo VHS/DVDR.
I hope you're within the return period. The device is specifically advertised as being "the best" for capture from VCR. Get your money back if you can.
Without something for TBC, no USB capture device will produce good results (that includes all of the recommended ones).
The following users thank msgohan for this useful post: overdrive80 (05-10-2022)
05-10-2022, 08:45 AM
Ok, thanks. Then will bought PCI capture device.
EDIT: The VCR is this:
Ohhh in specifications indicates that s-video output is only for DVD.
Perhaps I misunderstood... do you mean that if the video does not have TBC, both the PCI and USB capture devices will not work for me?
From his answer, he had drawn the conclusion that with the PCI capturer he could capture with better results. I am very inexperienced in this matter.
As the links to the VCR images have been removed I have attached them according to the forum rules.
05-10-2022, 12:29 PM
lollo2 lollo2 is offline
You need lineTBC correction (at least) in both cases (except if you own a Canopus NX).
msgohan suggested you one of recommended capture cards (USB or PCI) instead of the UCEC card.
The following users thank lollo2 for this useful post: msgohan (05-11-2022)
05-10-2022, 12:38 PM
Thanks for the clarification. Among my little domain of the language and my lack of experience in this area did get me wrong conclusions.
05-10-2022, 01:19 PM
The S-VIDEO connector output is for the DVD player portion only. It does not provide video tape playback output.
05-10-2022, 04:20 PM
Thanks, already saw it in the manual, its a pity.
How to acquire a video in my country with TBC, is there the possibility of acquiring a separate TBC device to insert it?
EDIT: I answer myself http://www.digitalfaq.com/forum/vide...time-base.html. Its a great forum!!
05-10-2022, 05:09 PM
"Head counts" are messy, some machines could be both correctly described as having four or nine heads depending on how you describe them; each manufacturer kinda just made it up.
Six heads I imagine is SP and extended head pairs and the HiFi heads. Some machines included a single trick play head and included that in the marketing count, some didn't, and some even included linear audio heads in the count.
I had a non-entity machine years ago which claimed to be '8 head', it was a sleight of hand with the numbers.
Audio capture: line in or capture card? thestarswitcher Capture, Record, Transfer 5 04-26-2022 04:30 PM
Video capture card that would capture all lines in NTSC? alltruefalse Capture, Record, Transfer 3 12-29-2018 01:48 AM
ATI All In Wonder video capture card, with capture computer, for sale [SOLD] kpmedia Marketplace 1 05-23-2011 02:09 PM
