Unscrew the BVP-4 and look inside. The fuse should be obvious. I'd take a photo of mine, but it's in use at the moment.
Rather than type out what I have, I just took a quick snapshot with my P&S camera. It's a bit blurry, but you can still read it okay.
If the unit powers on, it should be okay. However, weak power may cause odd errors like this on electronics, so it might be worth the quick check.
I don't want to jump to the conclusion that the unit is dead.
If this on a power converter of any kind. What country are you in? Is it being fed a PAL or NTSC signal?
