02-08-2004, 12:53 AM
jrnyhead jrnyhead is offline
Is there a way to install just the TV capture using MMC 8.2 without installing the other software like 'File Player, Video CD, CD Audio, LaunchPad, ect'?
The reason is, these apps run as defualt when MMC is installed and I wish to ues other software programs like PowerDVD or Roxio.
The MMC software does not let you choose not to install these apps. when using "Custom Settings"
02-08-2004, 04:15 PM
admin admin is online now
That may not be needed.
Is the problem that you simply like to double-click on the MPEG/AVI files, and it launches ATI MMC File Player or ATI MMC DVD Player instead of something else?
Or that it autoplays a DVD-Video when inserted in DVD-ROM, and you don't like that either?
02-08-2004, 11:24 PM
Yes.............
You nailed it right on the head!
This is what I don't like about MMC.
02-09-2004, 01:23 PM
Leave al of the ATI MMC components installed. They are fine. But like me, you do not want to be forced to use their sub-par DVD player or problematic file player (only the capture tool is good).
This is ACTUALLY a Windows issue.
You only have to do this fix ONCE (unless you re-install new media software):
To change this, HOLD THE SHIFT KEY and then RIGHT-CLICK on the file you want to open. In this example, I'll open an MPEG file.
In Windows ME, 2000 and XP .. it also has the SUB-MENU where you can pick the CHOOSE PROGRAM option. Do this.
A screen will appear where you can choose the program YOU want to use in order to open ALL FILES OF THAT TYPE.
In your case, pick WINDOWS MEDIA PLAYER (or MICROSOFT WINDOWS MEDIA PLAYER, depending on which version of Windows and WMP you have installed). Then tick the check box and click OK.
From now on, all files of that ype will play with THAT PROGRAM.
This works on ANY FILE and ANY PROGRAM in Windows.
If need more help, let me know.
You do not need to uninstall ATI MMC components, just don't use them. (They must be installed anyway).
Research for OSx86 install, Hackintosh notes admin Computers 0 08-11-2009 12:37 AM
ATI software tebriel Capture, Record, Transfer 6 01-02-2009 01:54 AM
Software for dvd-rom staypuftman2004 Computers 4 09-26-2006 06:04 AM
ATI MMC 7.7 hack install guide admin Capture, Record, Transfer 0 02-15-2005 05:22 AM
AIW 9600 Install Problems jrnyhead Capture, Record, Transfer 2 04-21-2004 04:02 PM
