Closed Thread
07-30-2010, 10:25 AM
kabal2000 kabal2000 is offline
I have been trying to cature video from my VCR using my ATI All-in-wonder 9600. When I try to cature the video, the end result is a choppy video, which appears to be a problem of dropping frames. This was as I captured into an MPEG format. I want to try to capture the video in an AVI format to see if that will help. I followed all your steps in setting up the capture info. When I try to record to an AVI file I get "RECORD ERROR" about 8 mins into the 25 min video. Does anyone have any ideas why I am getting that error?
07-31-2010, 03:21 AM
Did you run down the list found on the Dropped Frames guide? Read that list at http://www.digitalFAQ.com/guides/vid...ped-frames.htm
"Record Error" may be due to several issues. A primary one is not having enough free hard drive space, or trying to record to a drive that is too busy or too slow. Capturing to a second hard drive is suggested. Also look to use the HuffYUV codec.
Let's try to keep this all in one thread for now, since it appears to be a single problem.
Let's continue at these posts: http://www.digitalFAQ.com/forum/show...ideo-2337.html
Thread locked.
Closed Thread
ATI AIW 9600 Drivers jrnyhead Capture, Record, Transfer 2 03-30-2008 07:31 PM
AIW 9600 best software updates? edgar9 Capture, Record, Transfer 7 11-04-2007 02:06 AM
Capturing AVI on ATI AIW 9600 TLin2100 Capture, Record, Transfer 2 11-30-2004 05:27 AM
AIW 9600 Capture from VHS jmolhava Capture, Record, Transfer 3 10-28-2004 12:01 PM
9600 AIW captures excellent, but authorware wants to reencode ? -d00d- Capture, Record, Transfer 4 06-12-2004 01:58 PM
