ATI MMC is currently on version 9.03
I am running 9.02 right this minute. It seems to work very well.
For as many years as I can remember, it has always been suggested to completely remove previous drivers and software for many devices. ATI cards are especially important to perform this operation. Not all software, unfortunately, comes in update/upgrade form.
It is unlikely that you will be able to capture copy-protected tapes without hacks or external devices like a TBC.
Version numbers are a funny thing. When you get right down to it, they don't mean much in terms of quality or stability. Newer is not always better.
Some naming/numbering quirks to consider:
- Windows 98SE probably should have been called Windows 2000 to stay in the same naming scheme.
- Windows ME should have been Windows 2001.
- Windows 2000 should have been Windows NT 5.
- Windows XP could have been Windows NT 6 and Windows 2002.
Nero Burning ROM 6.x.x.x is often considered inferior to
Nero Burning ROM 5.5.10.x because of all the new bugs it has in regards to DVD-Video burning.
- Pegasys Inc's
TMPGENC encoder had a quirky way of numbering software. It was all version 2.5.x ... where "x" was a number noting the new update. HOWEVER, it did not use leading zeros. Version 2.5.2 was 18 versions before 2.5.20, because they used 1,2,3 ... etc ... 10, 11, 12 ... etc ... up to 20, 21, 22. They should have done 2.5.02 for the second edition of v2.5, or jumped to 2.6.01 after 2.5.9 to fix the naming errors.
- ATI used up the version 8 numbers too fast. They went from v8.0 to v8.9 in about a year's time, and the software barely changed. While v7.x is HUGELY different fro 8.x, 9.x is almost the same as 8.x. They should have started using 8.xx or 8.x.x versions, but seeming waited for v9 to implement a v9.xx system.
- Sonic DVDit! went from 2.5 to 5.1 with no in-between versions!?
Adobe and lots of other companies are doing screwy things with versions, instead using cutesy names like "CS" and "Elements".
