Quantcast 128 Pro Hack ( I need therapy) - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > DVD Project Help > Capture, Record, Transfer
01-12-2006, 11:15 AM
GMaq's Avatar
GMaq GMaq is offline
Hello,
I recently upgraded my mobo & processor to an Intel 865 PERL with a P4 3.4 GHz, the board has an almost extinct AGP 4x/8x slot so I was able to retain my prize possession ATI AIW 128 Pro. The 128 PRO hack was working fabulously on my old system under XP SP2, long story short I've attempted to do the hack on my new system (also XP Home SP2) and can't get the .bat file that allows the install to start to run in my Windows temp folder. It will run from pretty much anywhere else on the computer including the desktop. I know for certain that I've done the steps properly and in the right order because I've done the hack numerous times for myself and others, and it worked fine on my old system even under SP2. The system doesn't seem to like running the .bat file from the temp folder, it opens the window and promptly disappears, When you run the MMC 8.7 exe file it copies the cab files to it's folder on the hard drive and just sits there without going any further. The card is working perfectly with VDub and iuVCR etc. but I am really missing the realtime MPEG capture that MMC can give me. Any suggestions?? Thanks GMaq
01-12-2006, 11:46 PM
Refer to STEP 10-A of the hack guide, where it shows "C:\Documents and Settings\John\Local Settings\Temp\" as the profile.
Try to execute the BAT file from inside one of the other profiles. ALL USERS or ADMINISTRATOR, for example.
See what that does, if anything.
__________________
If this site has been as helpful as a book or magazine, then donate a few dollars or consider upgrading your membership.
You must be logged in to view images and download attachments.
01-13-2006, 06:15 AM
GMaq's Avatar
Hi,
No dice on changing the temp folder, I'm beginning to wonder if some of the latest XP security updates are interpreting the execution of a .bat file from the temp folder as Spyware although I was not running my spyware or anti-virus programs when I did the hack. I was however able to find an old version of MMC 7.7 on a CD I had laying around and although I've never been able to get it to install with a non-radeon card, it worked this time WITHOUT needing a hack file and so for now I have basic DVD MPEG capture. Thanks for the suggestion anyway.- GMaq
KISS DP-450,470,500,508 - DVD player hack lordsmurf Home Entertainment and Videography 0 03-01-2009 02:44 AM
Denon DVD-1910 - DVD player hack lordsmurf Home Entertainment and Videography 0 03-01-2009 02:41 AM
LG DR275 DVD recorder hack help MuppetDanny Home Entertainment and Videography 3 10-30-2007 04:07 AM
128Pro Hack with XP GMaq Capture, Record, Transfer 1 05-02-2005 12:52 PM
ATI MMC 7.7 hack install guide admin Capture, Record, Transfer 0 02-15-2005 05:22 AM
All times are GMT -5. The time now is 12:14 PM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
