Quantcast MPEG-2 Parameter Values: ATI vs. General - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > DVD Project Help > Capture, Record, Transfer
01-22-2006, 03:40 PM
mitch mitch is offline
Can you comment further on recommended MPEG-2 encoding parameter values
as it relates to VBR target vs. max bit rates, Motion Estimation
Quality, etc? (This is primarily w.r.t. the values referenced in the
"Capturing MPEG with an ATI card" guide). Some questions are as follows:
I notice that the Target Bit Rate (TBR) is set very close to (almost as
high as) the Max Bit Rate (MBR) in the examples (templates) in the
guide. Is this due to your experience with the way the ATI card's
hardware and software functions? I would think a perfectly efficient
system (would probably not exist in real life) should be able to have
its TBR set at a somewhat lower value and then be able to
"instantaneously" grab whatever higher bandwidth needed (up to the
maximum setting) as required. Have you found that unless the TBR is set
close to the MBR that the system cannot efficiently grab the required
additional bandwidth when needed, thus producing pixelated video on
occasion?
Also, can you comment on the Motion Estimation Quality setting(s)? The
MEQ setting of 99 in the guide seems very good as the maximum for the
scale is 100. I assume this means that ATI does a very good job of
estimating motion??
Should one assume the values referenced in the guide should only apply
to the ATI card hardware and software, or would they also apply to other
encoding hardware and software in general? What would be the most
efficient theoretical settings?
P.S.
I used TBR of 3.92 Mbps, MBR of 4.03 Mbps, and MEQ of 99 (almost
identical to the recommended settings in the guide) with ATI MMC version
9.03 and ATI AIW 9000 Pro card for my 8mm to DVD home movie project and
these values appeared to work fine. I'm just trying to understand more
about these settings from a theoretical vs. practical standpoint.
01-22-2006, 10:34 PM
"Active" VBR streams, regardless of what you specify, can only vary by so much. ATI encodes operate a bit more like CVBR (constrained variable bitrate). It has a range, but it's not a huge range. A lot of DVD recorders work this way too (LiteOn, for example, and Panasonic).
You can specify 15,000k if you wanted, but if you load the captured video into a bitrate analysis tool, you'll notice the spikes are small. When you specify a value that is too high, it also has a tendency to go too low. It can over-compensate.
You've got to remember that an "active" VBR capture only has a buffer than is so big.
Compare this to a VBR encode done complete in software, loaded from an AVI file. It usually doubles the encode time, often taking an hour at minimum, to analyze the file for the best VBR allocation. WHen you capture to VBR, you skip this step. You get a 1-pass quickie guestimation based on what's loaded in the buffer.
Now that's sounds sloppy, and it really is, but it's still better than CBR (unless you set the CBR bitrate to the max allocation spec for the resolution, such as 4000-5000k at 352x480). VBR is meant to not take up space, only use what is needed, when needed. Sloppy or not, it works fine almost all of the time, as long as you give it a good bitrate.
Think of VBR capturing as CBR with a bonus. It will use a small bonus if given the option, when needed, but it'll basically capture CBR at the average you specify most of the capture time.
Certain capture chips (like LSI chips found in JVC DVD recorders) have a very large buffer, which explains how it can both filter video noise, as well as do a decent VBR encode. The JVC has a range of about 1200k up from max, and it really does use it.
Motion estimation is how MPEG works during the encode phase. This is really hard to explain, but I'll try my best.
Estimation is a scientific was of saying "educated guess". When a football player is running across the screen, it guesses from frame to frame. This deals with temporal compression. There is also a relation here to deciding it's time to use more or less bitrate.
In some encoders, this is also a basis for encoder-controlled GOP length and GOP type. ATI MMC only does the GOP type specified, it is not "smart" here like Procoder or other advanced MPEG encoders.
I don't really know what else to say here. This is one of those super-techie MPEG topics. Give this a gander: http://www.cs.cf.ac.uk/Dave/Multimedia/node259.html
Basically, the settings shown in the ATI MMC guide only apply to the ATI Theatre chipset, and devices of a similar nature. Other hardware can vary, as can software encoders (TMPGEnc, Procoder, etc).
TMPGEnc "CQ" mode is more similar to CVBR. It uses a % instead of hard Mb/s (k) bitrate values, but it's the same thing. For example, 85% of 4000k is 3400k. This is a setting that matches the ATI MMC almost identically.
I use a lot of ATI MMC with 352x480, 3420k average, and 3900k max. I've set it for all kind of things higher before, and rarely did it use anything higher. Feel free to try on your own. Remember I have the Theatre Rage/100 chipset, the so the 200 may be a bit more advanced. Now that cards have come down a bit in price, I may grab a 9800 AIW in the near future.
Practically, give yourself a max about 400k-600k above the target.
__________________
If this site has been as helpful as a book or magazine, then Donate a few Dollars or Upgrade your Membership.
Converting a 12GB Mpeg to a 4GB Mpeg Konfusion Encode, Convert 1 09-03-2007 06:06 AM
MPEG-2 vs. MPEG-2 DVD in MMC TV Capture JimGorsline Capture, Record, Transfer 4 07-09-2004 02:20 AM
Video editing - general myron Encode, Convert 2 04-28-2004 04:29 PM
All times are GMT -5. The time now is 12:18 PM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
