03-21-2011, 06:32 AM
Lordsmurf,
Thanks for the reply. I've decided to hardware capture directly to MPEG-2 format. I've done a lot of reading at your website and still am at a loss as to the best way to proceed. What's an excellent MPEG-2 hardware MPEG-2 capture device with software that you would recommend using on a Windows 7 system?
Thank you very much.
My default answer is to get one of the ATI 600 USB cards.
Works well, Windows Vista or Windows 7, captures to MPEG for NTSC. (Not for PAL, however. For PAL, only AVI via VirtualDub.) Or AVI in NTSC, using VirtualDub.
The ATI 600 USB comes with ATI CMC.
I've tested it on Windows 7 64, no issues at all.
Amazon is your best bet: http://www.amazon.com/gp/product/B00...SIN=B0035BJGYW
This model was made in 2008 or thereabouts, so it can only be found used or refurb.
The best video gear was made years ago -- most new capture cards are crap, excluding high-end stuff from Matrox, Blackmagic, Aja and some others. If you have a budget of $500, then we can go over those, if you'd like.
VHS Capture Device Advise Drazick Capture, Record, Transfer 34 06-16-2011 05:46 PM
Software vs. Hardware TBC jmac698 Restore, Filter, Improve Quality 3 12-23-2010 05:21 PM
Advice on VHS capture setup (capture device, proc-amp, recommended connections) Simon76 Capture, Record, Transfer 12 12-23-2010 03:46 AM
I need a capture device that does 768*576! lzrplayr Capture, Record, Transfer 4 02-11-2010 08:38 AM
Mpeg capture software for PVR 350 mlaviolette Capture, Record, Transfer 2 11-30-2004 01:08 PM
