12-30-2016, 12:13 AM
SoManyTapes SoManyTapes is offline
I am currently testing out a Diamond VC500 USB capture device and am having trouble getting it to work with VirtualDub. The card appears to work with other DirectShow capture applications (I tried VirtualVCR and STOIK Capturer, and creating a capture graph manually with GraphEdit), but when I try to capture in VirtualDub I get an error "Unable to start video capture".
The log shows "CapDShow: Unable to transition filter graph to run state: hr = 800705aa ()". The error code translates to "insufficient system resources" which isn't terribly helpful.
I have tried both the x86 and x64 versions of VirtualDub and haven't had success with either.
Has anyone had any success with the VC500 and Windows 10 using VirtualDub?
12-30-2016, 03:14 AM
Why are you using graph edit?
I use VirtualDub and the VC500 to capture on an XP desktop, a Windows 7 desktop, and a Windows 10 laptop. If you didn't install the VC500's software and configure EZGrabber, you won't be able to use VirtualDub with the VC500 without the help of something like GraphEdit, which is a really complicated way of doing it.
12-30-2016, 06:33 AM
I was just using GraphEdit to test if the capture device works with DirectShow - I'm not going to use it for captures. I have installed the EZGrabber tool and that works too, but I'd like to use VirtualDub to capture to Huffyuv instead of the MPEG-2/4 compression that EZGrabber uses.
12-30-2016, 07:55 AM
You don't use EZGrabber to capture. You run a one-time setup and set it to "Record" to AVI, then turn it off. You use Virtualdub in its "Device" menu to select Conexant Direct Show as the capture device. The EZGrabber software has the VC500's capture drivers and proc amp image controls. If you install Windows 10 drivers VirtualDub should be able to see the device.
If you're using 64-bit VirtualDub, it won't work. set up your capture and post-processing for 32-bit.
http://www.digitalfaq.com/forum/vide...html#post45219
01-03-2017, 06:17 AM
It seems to be working now ... I solved the problem by downgrading the drivers from version 7.0 (in the 2016 release on the Diamond website) to version 6.0 (the 2015 release).
01-03-2017, 07:17 AM
As you and many users have discovered, Windows 10 is a quagmire of hassles with a great many devices, not to mention capture hardware. You'll find many posts here and elsewhere mentioning workarounds for a ton of stuff that would otherwise work easily in XP or Windows 7. I have one Windows 10 computer that even gave me a problem with mouse and keyboard drivers that work in every other computer I've used!
Glad to see you have it working. Your post will be helpful to others.
Issues with Legacy VC500-USB mtetreault Capture, Record, Transfer 12 07-02-2019 06:37 PM
VirtualDub error upon capture / test capture? dinkleberg Capture, Record, Transfer 5 09-05-2016 04:07 AM
Diamond ATI 750HD PCIE - Problems capturing, black overlay after first capture danexpo Capture, Record, Transfer 6 11-30-2014 11:37 PM
VHS capture to AVI with VC500 -- thoughts? jmt0 Capture, Record, Transfer 15 01-14-2014 08:57 AM
Diamond GC500 USB Capture Card ben_r_ Capture, Record, Transfer 3 09-14-2012 11:32 AM
