08-26-2004, 09:12 AM
mlaviolette mlaviolette is offline
Some people say that Monster Cables are overpriced and that there are less expensive cables of equal or better quality available. Would you be able to recommend other manufacturers and also list the ones to avoid?
08-26-2004, 12:31 PM
I would buy MONSTER cables without a second thought. They are expensive, yes, very much so. But they are easy to find, and are well insulated, good gauge wire, good materials, and low signal-to-noise ratio.
A good runner-up would be thick gold-plated cables from Radio Shack.
Blank Blu-Ray media recommendations Elephants_Never_Forget Blank Media 1 05-25-2011 07:48 PM
Are there fake Monster cables? Explain difference in price? admin Capture, Record, Transfer 0 10-18-2010 05:35 AM
Hi8 Capture HW/SW Recommendations djam0000 Capture, Record, Transfer 8 02-24-2010 10:24 PM
How to split cable TV and cable internet coax for two rooms ? stoogedog Computers 6 12-05-2006 06:15 AM
DVD Player Recommendations? mitch Videography: Cameras, TVs and Players 5 03-18-2005 07:05 AM
