10-22-2018, 03:04 AM
Mejnour Mejnour is offline
Hi Guys,
I am in France now, dealing with L-Secam video (typically old France signal).
I have 2 JVC vcr. HM-DR10000EU and HR-S7600MS.
"EU" deck doesn't support L-SECAM, image is black and white. Fine.
"MS" deck play secam tape normally.
In the 7600MS manual we can read that the TBC/NR function will not work with Secam signal.
On the other hand I was wondering if it would be possible to used a second deck with TBC in passthrough mode to get the benefit of the JVC TBC? I assume that I will need a kind of transcoder Secam--->PAL between the 2 decks to make it work?
Any others workflow for this signal is welcome
10-22-2018, 05:15 AM
Short EDIT
Playing the secam tape with the MS deck with the color setting on "AUTO", I can capture with ATI AIW with capture filter on "L-secam". The image is unstable (bounce) and color are washy. Same thing if I put the deck in color mode "PAL"
while capture in PAL, but color more vivid.
When a put a second JVC VHS between in passthru mode, I get stabilized image despite that I get the impression that the TBC have no effect in passthru mode. So far it look like passthru is the way to go. New set-up, interesting.
As state in my original post, I put the jvc HM-DR10000EU between, so I had to capture in PAL meaning that the JVCHR-S7600MS did the original color conversion from SECAM to PAL.
I guess if I had 2 "MS" deck, I could do a SECAM capture test in passthru mode....
10-22-2018, 11:24 AM
Edit #2
Tapes collection that I am working on are L-secam quality LP.
Would like to know if the same tendancy apply in PAL/SECAM for quality tracking....Panasonic better for LP/EP tracking vs JVC better for SP.
Maybe fellows europeans can gave me input on the topic.
10-22-2018, 12:00 PM
If you have tapes recorded on a French market VCR ("true SECAM" or SECAM-L), the TBC should work on them with a "MS" deck according to the manual. MESECAM or Middle East SECAM tapes are a different format.
10-22-2018, 12:42 PM
As previously stated in my inititial message, unfortunatly TBC doesn't work with SECAM or MESECAM (ref. JVC HR-S7600MS manual)
10-22-2018, 01:02 PM
Originally Posted by Mejnour View Post
Short EDIT
The TBC function in most VCRs doesn't work when passing the signal through, the HM-DR10000EU may be more of an oddball in this regard (maybe it's because it presumably has a video encoder chip somewhere to record analog signals to D-VHS.) I believe the TBC in e.g the HR-S7600 works directly on the rf signal from the tape somewhere before it's modulated to an S-Video or Composite output signal.
Good JVC decks that can play SECAM and PAL? autephex Capture, Record, Transfer 9 02-10-2023 11:44 PM
SECAM-L conversion to DVD? photoguy1234 General Discussion 3 10-28-2016 03:15 AM
ATI All In Wonder Radeon 7500 PCI for SECAM? autephex Capture, Record, Transfer 11 10-29-2014 12:14 PM
MESECAM/SECAM VCR's Buying Guide? tomswift Restore, Filter, Improve Quality 13 09-30-2013 01:27 PM
