Sounds okay to me.
I'll do some research and see if I can find that driver version that seems to be causing you problems.
I just did a complete XPSP0 then +SP2 install.
I corrected my video controller driver problem, and made sure a yellow cone warning about a USB port was fixed before I began installing the CDROM for the ATI capture device.
I then put the CDROM into the tray and let it autoboot the ATI installer.
I then clicked Install
Then clicked Express install
Then waited until the installer "told me" to connect the ATI capture device for the first time, it was
not connected to the 110 Volt/+6 Volt power source. I plugged the USB cable from the ATI capture device into the PC.
Then I plugged the 110 Volt/+6 Volt power source into the ATI capture device.
I waited 2 minutes and the installer detected the ATI capture device was plugged in and continued the install. I did not touch the keyboard at any time after plugging the 110 Volt/+6 Volt power source into the ATI capture device. It took a while but the installer detected the device was connected and automatically continued the install.
It installed several things and stopped when it started to install the Guide+ software and asked for permission. I granted it permission, and it continued.
The installer finished and asked for permission to reboot. I granted it permission and the system rebooted. The CDROM was still in the drive.
After reboot the MMC toolbar was visible on the right.
I immediately checked Device Manager, there were no yellow warning cones, all of the ATI capture device drivers were installed.
I checked the version of the device driver for [ ATI TV WONDER USB2.0 Video & Audio ]
It said:
ATI
8/19/2004
6.14.10.6314
I clicked the ATI MMC TV tuner application and it began First setup, completed that and audio and video worked as expected. It displayed tuner static and emitted sound. I switched it to S-Video and it captured video and sound from my tivo s-video output and played it properly.
I copied
VirtualDub 1.9.11 and
VirtualDub 1.10.0 to the desktop.
I started VirtualDub 1.9.11 and it worked as expected, it captured video and sound. I did have to turn Enable audio playback on to hear the sound.
I started VirtualDub 1.10.0 and it worked as expected, it captured video and sound. I did have to turn Enable audio playback on to hear the sound.
So this is with a complete install of the 180_V01089_100 CDROM on Windows XP wth Service Pack 2 on it.
I have not been able to reproduce the "no sound captured" problem your seeing.
The only difference I can see at this time is the Device driver version you have installed is:
ATI
1/25/2005
6.14.10.6317
which is not the version that came on the CDROM that came with all of my ATI TV WONDER USB2.0 capture devices.
At this point I can only "guess" the problem is that Driver version has a problem.
I've uploaded a compressed rar split copy of the CDROM that came with my ATI capture devices above. It is in in three parts.
If you download those and use something like 7Zip it can extract those into a CDROM image file with the .iso extension.
There are several ways you can use that to attempt a new install on a fresh install of Windows XP SP2 like I did. And I would expect it to work.
I've really only seen one instance ever of these ATI USB2.0 capture devices fail, and it was totally non-functional, it did not partially fail. Its red LED on top did not even light.
If I could get a copy of the driver that you have been trying I could try to reproduce your results and diagnose the problem. But without it I'm dead in the water.
I'll try finding a copy of that driver on some other Driver archives for other ATI cards.. the ones that came after that device usually had some legacy drivers included on them too.. if I can find it I can confirm if it has a problem by installing it and attempting the same vetting procedure. Finding that specific driver version may take a little time however.. it would be quicker if I knew where you got it, or could get a copy of the one that you have.
It would be useful to know so that if other people have a similar problem we could tell them not to use that version.
These boxes are remarkably stable and long lived. Only their power supplies need to be changed out occasionally.
When they work properly you have lots of controls available that aren't usually available with other devices.
