07-12-2020, 08:41 PM
WaxCyl WaxCyl is offline
The BE-75 can only output 10bit, but internally uses 12bit processing to maintain signal accuracy.
Are you using AVIsynth+ ver3.6.? Sounds like you need to update QTGMC as well if you are still using YUY2?
You need the pinterf versions of all the QTGMC dependencies. Yes, I too used M.Express.
07-12-2020, 11:56 PM
I don't know what AVIsynth+ version I'm using, I remember it was a nightmare to get the whole thing to work error free, I sure hope I don't have to go through that again, I didn't mind converting to YUV2 because I have to crop to 704 using vdub2 so in the process I save as YUV2 but it would be nice if I can get QTGMC and FFMPEG to work without YUV2.
Broadcast Grade TBC - Leitch DPS-475/575 review LukeS Restore, Filter, Improve Quality 36 10-11-2019 08:12 AM
FS: Two Pro TBCs - Novamate Novatrol and Leitch DPS-235 vandepas Marketplace 0 09-06-2014 06:02 PM
Putting the DPS/Leitch DPS-235 TBC to the test NJRoadfan Restore, Filter, Improve Quality 9 09-19-2012 10:44 AM
Toshiba SD23VB has a TBC? Pattern effect using s-video? via Email or PM Project Planning, Workflows 1 03-08-2012 10:17 PM
AV TOOLBOX 8710 Shows B&W Test Pattern rocko Project Planning, Workflows 5 09-17-2011 09:15 PM
