05-18-2018, 03:39 AM
wigam wigam is offline
Hi,
capped a short clip of this show, looks to be broadcast at a low sd res.
I have re-encoded to MPEG-2 dvd compliant file. Would it be well served to filter it? If so what filters?
thanks
05-18-2018, 07:16 AM
It's field-blend deinterlaced. That's permanent damage. Nothing you can do
05-18-2018, 11:40 AM
I have attached a sample of the cap rather the final encode. In case it was something i had done.
Still pointless?
thanks
05-18-2018, 01:11 PM
What are you using to capture this avi? It's frame rate is 48.2 fps, it has out of phase duplicate fields and telecine glitches. It's crapped-up video from the word go. I can't believe it was broadcast that way, and no way was it broadcast at that frame rate. Youy can tell it was film source, which is never simple interlace.
If its' "low sd res", how did it get to be 1920x1080?
05-18-2018, 07:59 PM
oops. i captured from hdmi output and satellite receiver upscaled it. used hd frame grabber i use for hd caps forgot different source when i capped.
I'll try some caps from video output and use ati capture
broadcast is 544 x 576 at 4.5 mbps
Recommend a good clip library manager? ehbowen Project Planning, Workflows 3 03-22-2018 10:04 PM
PhotoDirector freezes at 99% while analyzing a clip? avz10 Edit Video, Audio 1 08-22-2014 07:22 AM
Trouble with scanning TMPGEnc authored clip unclescoob Encode, Convert for discs 3 02-01-2013 01:21 AM
Still clip jump SSStudio Edit Video, Audio 12 12-06-2009 03:24 PM
HD video clip has stuttering playback ? manthing Videography: Cameras, TVs and Players 3 02-12-2006 12:19 AM
