05-17-2019, 02:18 AM
frankzaatar frankzaatar is offline
I'm using this deck to digitize old cassettes and I wanted to make the audio sound better. So I thought that taking the audio from the XLR outputs would be better, as this is the professional output. So I got myself an XLR to RCA adapter, but to my surprise no audio comes out of the XLR. When I connect the RCA cable to the monitor output, I can hear the audio. What do you think?
05-17-2019, 04:32 PM
Which of the outputs did you use? These decks have two sets of audio outputs (in addition to monitor and headphones). Can't find the manual for this specific one, but I would assume it's similar to the older models. The Hi-fi output only outputs if there is hi-fi audio on the tape. The other one (norm/hi-fi) outputs hi-fi if there is, otherwise normal, but can be forced to normal with a switch on the front panel.
Alternatively you can try the headphone output on the front of the unit.
XLR won't really help unless it's used at both ends, though the monitor out only gives you mono audio (which only matters if you have a tape with hi-fi or linear stereo), . XLR (balanced) will be less suspectible to noise than RCA/Phono (unbalanced), but I don't know how much difference it would make for a VCR.
Panasonic AG-8700 S-VHS VCR: a problem with TBC frankzaatar Restore, Filter, Improve Quality 2 09-05-2017 03:26 AM
Panasonic AG-8700 PAL S-VHS VCR (1997) Quasipal Restore, Filter, Improve Quality 8 05-31-2017 05:13 PM
Scrolling in Panasonic AG-8700 full frame TBC? paulopereira Video Hardware Repair 7 08-21-2015 10:54 AM
Panasonic AG-5700E vs Panasonic NV-HS1000 for transferring tapes? tsakodim Capture, Record, Transfer 8 12-31-2014 10:00 AM
Can my Panasonic DMR-ES10EB record Freeview channels from my Panasonic TX-L-32G20B TV Peter_T_Ross Videography: Cameras, TVs and Players 4 09-01-2010 05:20 AM
