11-29-2021, 06:36 AM
enois enois is offline
I already own a Panasonic ES10 but, since most of the tape I want convert are master or 1st generation copy in good condition, I am looking for a (PAL) DVD recorder with TBC function on passthrough, more transparent on image even if less strong in TBC than Panasonic's ES10/15.
I have the opportunity to buy from trusted sources one of the following DVD recorder: someone can tell me which one can have some kind of TBC effect on passthrought?
Pioneer
DVR 520H
DVR 720H
DVR 630H
Panasonic
DMR HS 2
DMR EH 57
Sony
RDR HXD 890
Thanks in advance.
11-29-2021, 08:49 AM
Are you in a NTSC or PAL region?
For PAL, the EH57 works great though it has the same brightness issues as with the ES10, otherwise it's quite similar, a tad less strong jitter correction on "extremely" bad tapes, though has a higher bit depth video decoder and HDMI output. If it's a US/Canadian variant it may not work well at all as Panasonic started using different chipsets for models from that year on and I know at least some of them have a very basic video decoder chip.
The PAL Panasonic DMR-HS-2 seems to have similar jitter correction as the ES10 according to a user here, though I have no idea about transparency compared to the ES10 and later other than that the menu-activated DNR function is reportedly not active on pass-through. I haven't seen any mentions on whether or not it has the same white clipping issue as later models though I suspect it might since otherwise e.g the gleitz forums would probably be more adamant in suggesting the old models specifically.
The 520 and 720 do not work well either as far as I know. I haven't seen any HXDx90 models specifically, though it seems to be based on the same chipset as the RDR-HX750 that I know works, just with a digital tuner, so of these alternatives, if you want something different to the Panasonic, I think you would want to go for either the DVR-530 or that one.
As far as I know, the PAL Panasonic DVDRs don't have the posterization issues that has been reported with the NTSC variants, the only transparency issue I know with them is that they tend to clip very bright spots (which can be worked around to an extent with a volume control or potentiometer or similar).
The plus points of the pioneer/sony models don't have the same problem as they let you adjust brigthness, contrast etc. They also have a soft border on the left/right compared to a sharp one from the panasonic models on the analog outputs. (The HDMI output gives you the whole 720 pixels on most dvd-recorders.) Mostly noticeable on PAL, NTSC usually has smaller areas blanked I think. The other plus point is that they do not turn off the analog outputs if the dvdr thinks there is no input connected like the panasonics. Usually that's not an issue but you can encounter it on tapes where something has been recorded without the video input connected. There are also going to be some minor differences in Y/C separation if using composite input but I can't really tell which one is better at it.
Also, at least for PAL Panasonic and Sony/Pioneer models give flashing brightness or half the image being darkened if the input has copy protection (Though I seem to remember that for the RDR-HX750 at least, the using HDMI may avoid it, but I'm not able to test that at the moment. HDMI does not evade it on the EH57.)
The following users thank hodgey for this useful post: enois (11-29-2021), Jbress (02-13-2024), msgohan (11-29-2021)
11-29-2021, 11:34 AM
Bogilein Bogilein is offline
Pioneer
DVR 520H
DVR 720H
DVR 630H
Panasonic
DMR HS 2
DMR EH 57
Sony
RDR HXD 890
Thanks in advance.
Pioneer 630 was the first Pioneer that was usable for jitter correction.
Sony 890 (2008) should be pretty similar in quality maybe a tad better (newer).
Panasonic DMR HS2 also similar to Panasonic ES10.
Here you can see a HS2 and a Sony 680 in action.
The Sony 680 and Sony 890 should be identical.
http://www.digitalfaq.com/forum/video-restore/12108-weird-horizontal-distortions.html#post79341
The following users thank Bogilein for this useful post: msgohan (11-29-2021)
11-29-2021, 01:31 PM
Thanks to both of you. I'm looking for PAL DVD recorder.
In my opinion Panasonic ES10 has some light posterization effect, but what I don't like is the aggressive NR and the contrast/brightness issue.
I no need of HDMI connection and Macrovision removal.
I will aim to the Pioneer DVR 630H.
Can you tell me the value of the potentiometer to use to adjust brightness? Workaround is possible in composite only?
11-29-2021, 01:52 PM
Or you modify your S-Video cable
https://gleitz.info/forum/index.php?thread/47744-tipp-digitalisieren-%C3%BCbersteuerter-signale-von-analogen-uralt-kameras-vidicon/&postID=462405#post462405
The following users thank Bogilein for this useful post: enois (11-29-2021)
11-29-2021, 05:48 PM
That's exactly what I'm looking for to adjust Y level in Panasonic DVD recorders!
Thank you very much.
Issue with rewind function on VCR diagia2 Video Hardware Repair 8 12-01-2021 08:13 AM
There is no function named Vinverse? (Avisynth) ELinder Restore, Filter, Improve Quality 2 02-19-2019 02:41 PM
Why JVC video Calibration function should be disabled? starport2 Capture, Record, Transfer 1 10-02-2016 02:13 PM
iMovie enhance function available in VirtualDub? premiumcapture Restore, Filter, Improve Quality 1 03-11-2014 10:55 PM
ATI All in Wonder 2006 PCIE: TV function does not work kennyb Capture, Record, Transfer 4 05-02-2012 07:02 AM
