01-03-2016, 08:29 AM
mr-vhsc mr-vhsc is offline
Hi All,
I would be much appreciated if the experts on here could have a look at my parts list to see if this build would be good enough to handle 4K video editing and rendering.
http://uk.pcpartpicker.com/p/wf4kxr
Many thanks in advance. If you recommend any changes then please advise and also why.
Regards
01-03-2016, 09:19 AM
Ehh... maybe. Video likes to eat CPU, and 4k eats more before breakfast than other videos eat all day.
Skylake is the future, not Haswell. I have the new i7-6700K, and it's easily faster than the i7-5820K. Most video operations are single- or dual-core, so the main factor here is raw clock speed. It's a 4.0+ vs a 3.3+. So the 6700K in practice is about 25% faster, regardless of benchmarking (mostly non-video use).
And with Skylake, all other hardware must change: motherboard, RAM, etc.
I'd even suggest putting the video on a scratch SSD drive for editing, and only store on HDD when done. That's what I'm doing. That removes most I/O bottlenecks, which, for this exact use, is the main video bottleneck these days.
The Noctua D14 cooler is far nicer. It makes no noise whatsoever with 1 fan (all it needs) and the noise adapters. It's easily the largest part of any computer that I've ever had, going back 30 years.
I'm using a pair of 1TB SSD Samsung 850 EVOs.
That Seagate 4tb is currently the best drive. I have one now, and the other is forthcoming.
Check out the Antec Three Hundred II case. Several members of this forum like it, as well as the 300 before that.
I just finished making all these decisions myself, back in October. My main system motherboard is having problems, and it was time to upgrade my 6-year-old AMD Phenom II Quad. Total cost was somewhere between $2k and $2.5k (USD). I'm hoping to have it for 5-7 years (~$35/month max for life of the system).
Just an alternative to consider...
01-03-2016, 09:56 AM
The 6700K has 4 cores whereas the 5820K has 6 cores. Is more cores not better?
01-03-2016, 09:59 AM
Nope. Cores often do not matter. It's why so many CPUs are still 2-4 cores, and no more. The software must comprehend more cores, and video software simply does not do that. Raw gHz clock speed and cache/instructions are what matter most. Sometimes you'll even find that raw clock speed doesn't matter as much as cache and instructions.
01-03-2016, 10:02 AM
Many thanks for your detailed and swift response. Much appreciated. New to all this so slowly trying to make sense of all this as i go along.
By the way what motherboard are you using with the 6700K. Also i have no intention of overclocking or adding any water coolers or anything of the sort.
01-03-2016, 02:43 PM
mnewxcv mnewxcv is offline
What software will you be using to edit 4k?
01-05-2016, 11:14 AM
i am looking to use Adobe Premiere Pro CC
01-06-2016, 02:36 AM
Goldwingfahrer's Avatar
Remembered
Premiere CC Subscription inexpensively
I work with Edius V.8.1
Best LCD monitors for video editing? via Email or PM Videography: Cameras, TVs and Players 1 06-30-2012 08:38 AM
Getting Closer: Computer Build for video capturing Kenneth M Project Planning, Workflows 15 03-09-2011 02:39 PM
Editing with Womble MPEG Video Wizard [VIDEO GUIDE] admin Edit Video, Audio 12 03-05-2009 10:39 AM
