07-27-2018, 12:22 AM
naripeddi naripeddi is offline
I have a bunch of external hard drives (both portal and powered) that hold back-up copies of personal videos and other data. They won't be used much, most of the time sitting on shelves.
What is the best way to store the hard drives and what kind of environment is required for their efficient storage (such as temperature...etc)? Are air-tight containers fine?
Would storing each of them on top of each other or next to each other create magnetic issues and cause data loss over time? Also, are there any special considerations that I need to take care of while storing them?
Regards
07-27-2018, 12:31 AM
Anti-static bags may help. But likely you already have a lot of aluminum or plastic around each drive, due to the enclosure, and that can already act like a barrier to static.
Air tight is never good for anything. I breed moisture. Sure, put it in a box or drawer, mostly to avoid dust. Hard drives are not sealed either. There are tiny pin-sized air holes. What you don't want to do is have drives sitting out where dust and daily particles get in them and on them.
No special case or storage is needed, though I've seen some nifty things in the past. Amazon and Newegg, as well as Fry's and Microcenter, are where I usually see them. I don't recall anything offhand. Just "hey, that's neat" and then I don't buy it.
Wood or cardboard is best. No cloth, or carpet, or anything like that.
I store most of my drives in a desk drawer where I'm currently sitting. That's all that's in the drawer: hard drives.
07-27-2018, 03:53 AM
Thank you.
NAS external hard drives: How do they work? Sossity Computers 1 01-08-2013 11:50 PM
4K hard drives for external RAID-1 USB2/eSATA ? lordsmurf Computers 0 04-01-2012 12:29 PM
Freeware for Recovering Data from external hard drives ? naripeddi Computers 7 12-19-2011 06:46 AM
External hard drives reviews: Best brands to buy ? hordeprime Computers 4 11-24-2006 06:14 PM
Sales on External & Internal Hard drives cp32 Computers 0 10-13-2006 06:07 AM
