Go Back    Forum > Digital Video > Video Project Help > Author, Make Menus, Slideshows, Burn
08-26-2009, 03:03 PM
dyfan dyfan is offline
Could either the Admin or Lord Smurf possibly create a general guide of some kind to explain the RIGHT way to make a background motion menu (for a DVD) that behaves correctly?
I have read that it would be necessary to create a dedicated file with a video frame size of 720 x 540...
Thank yooo!
The following users thank dyfan for this useful post: admin (08-27-2009)
08-26-2009, 05:10 PM
For the safest video, it should be
  • progressive format 29.97fps at at 720x480 (for NTSC) or
  • progressive format 25fps at 720x576 (for PAL)
As far as a more detailed explanation of this process, I'll make this one of the first new guides added to The Digital FAQ when site upgrades finish in September.
Some very quick instructions have already been added here ... http://www.digitalfaq.com/forum/show...menus-448.html ... which showed the menu creation process on a hobby project.
08-26-2009, 06:02 PM
Originally Posted by admin View Post
A guide for using Ulead DVD Workshop 2 is now posted. See http://www.digitalfaq.com/forum/show...l?goto=newpost
Your menu image must be 720x540 in resolution....
I have misinterpreted your words from your above reply (to another member), then? You were referencing a still menu background resolution and not a motion menu background???
The member said he wanted to create short motion menus backgrounds...
08-26-2009, 07:44 PM
Still images used in most authoring apps, whether used as an alpha overlay (image with "see-through"/transparent areas) or as a still image background (solid image), usually work best as 720x540. These assets are imported separately from the others (audio, video, subtitle text).
For whatever reason, a 4:3 storage (720x540) looks best. Otherwise, a 720x480 (3:2 storage) will be stretched up to 720x540 for working in the authoring app, then exported to DVD at 720x480. This double resizing process (stretch, then squish) is harmful in most cases, clear loss of quality. But a single resize from 720x540 4:3 to the 720x480 3:2 storage appears fine.
If you're wanting to mix video and still, then the other option is to do fully-video menus, as is discussed on the other X-MEN hobby project example in Premiere. Don't mix the image+video assets in the authoring app. The alpha layer (partially transparent) images are used in the video editor at 720x480 instead of 720x540, and are part of the 702x480 video output.
I know this is confusing. Ask questions if you need further explanation. I'm trying to quickly answer a fairly complex question. Making it easier to understand is going to take some thought. You more or less have to just understand video and images work differently, don't try to relate them. This is completely a DVD authoring software issue, present in most GUI-driven authorware.
How do I author a menu in DVD-Lab Pro ? lordsmurf Author, Make Menus, Slideshows, Burn 6 05-20-2011 07:02 AM
Your DVDs reviewed - Menu techniques, video/audio quality, and what else? kpmedia Project Planning, Workflows 0 07-05-2010 12:10 PM
DVD menu template/guides downloads ? manthing Author, Make Menus, Slideshows, Burn 4 08-28-2006 08:01 AM
How do I re-author Panasonic-made DVDs ? lordsmurf Edit Video, Audio 5 12-08-2005 07:26 PM
DVD2ONE guides admin Copy DVDs, Duplicate, Replicate 0 02-13-2004 12:21 AM
