12-30-2020, 06:37 AM
Qual cabo adaptador SATA/USB eu devo comprar para usar meu drive leitor/ gravador de DVD interno SATA em USB fora do PC?
what is your recommendation for me internal ou external drive? I have to choose one of the brands that supports M-DISC Do you recommend LG, Lite-On or ASUS?
12-30-2020, 07:10 AM
Can any of those exact models allow burn scans?
12-30-2020, 07:27 AM
I don't know but they are just DVD drive burn and read
What type SATA / USB adapter cable should I buy to use my internal USB SATA DVD reader / writer drive outside the PC?
what is your recommendation for me internal or external drive? I have to choose one of the brands that supports M-DISC Do you recommend LG, Lite-On or ASUS?
12-31-2020, 05:47 AM
I'm going to have to create custom responses that only Site Staff can use. Usually it's for certain repetitive topics, but it will be for certain repetitive people as well.
"Dear gamemaniaco, no further information or opinions are available at this time."
... followed by a thread lock.
I'm not joking. My time is too thin for this. You're not banned because you ask good question. But you ask the same question over and over and over a gain. STOP IT!
12-31-2020, 05:52 AM
please don't do this to me i need to buy a drive and i don't know which cable to choose to use the internal outside the pc and the brand i mentioned
excuse
12-31-2020, 05:58 AM
I don't know offhand either.
I have all 3 brands of DVD or BD burner.
- LG is cheap, usually fine, but I don't like LG as much. But don't let my preference influence here.
- Asus is more finicky. At one point, I think Asus rebadged (maybe still does?), and maybe Pioneer some years ago?
- LiteOn is all over the place.
Again, I'd search for details on which drives (if any) allows useful scanning. That's be my pick these days.
The problem = I don't have current data on the newest drives.
Newest media, yes.
Newest drives, no.
I am exactly 5 years outdated on drives. In 2021, spring/summer, I'll surely correct this. But not now. Busy.
If not looking for scanning, then price would be factor. Burning won't be much different.
At one point, LG was only M-DISC drive. But now? I don't know. Look at the specs of the drives.
12-31-2020, 06:02 AM
I don't know which one to choose because maybe they have better or worse readers and some brand burns better and has better error correction but these 3 brands read mdisc
on the sata / usb3.0 cable can you supply enough power to power an internal drive?
ASUS
model: DRW-24F1MT (90DD01Y0-B30030)
12-31-2020, 06:05 AM
What are all 3 exact models?
I'll do about 2 minutes apiece for some Google-fu for you, few things I can quickly look at.
12-31-2020, 06:09 AM
At the moment I would have to search other LG and LiteOn models but the model that was easier to find was this model from ASUS it is at a good price but I never used ASUS
I thought that this choice was directly linked to the brand and not the model but these 3 brands are the only ones with M-DISC support
has the status of the adapter cable to power the internal drive
Lordsmurf thanks for your patience and help
12-31-2020, 06:45 AM
That Asus is probably fine. Current burners don't differ much. Not bad, not excellent, but all moderate, commodity items now. It's not like when we had Samsung, Pioneer, Plextor, BTC, BenQ (all good drives), along with lots of not-good drives. My BenQ is sadly failing now, Pioneers have all failed, maybe a single Samsung external is fine, etc. Drives don't last long. The tuny mechanical optics wear.
I have an Asus in my main system, DVD only, works quite nicely for reading, average for burning, about 10 years old now.
12-31-2020, 06:49 AM
For my case I will save storing the drive to use in the future because these drives will stop being manufactured
is it possible with some software to test whether the drive is good or bad?
does the sata / usb cable have enough power to power the internal sata drive? I need this cable to use the internal drive outside the PC
12-31-2020, 06:55 AM
Read a disc.
Burn a disc.
If available as a feature, scan a disc.
Really not much else can be done. After you see it works, store it away. I have some extra drives in reserve, too!
12-31-2020, 06:58 AM
The power of an internal sata drive is how many volts and watts? which SAta to USB cable do I purchase to use the internal drive outside the PC via the USB 2.0 or 3.0 port?
12-31-2020, 07:00 AM
12V, I think. But it's not important to you. You cannot use a generic USB cable. It must be an enclosure made for optical drives. Opticals are not HDD/SSD.
12-31-2020, 07:02 AM
where do I buy this accessory to use the internal USB drive? I have this cable
https://encrypted-tbn0.gstatic.com/i...vhcKQ&usqp=CAc
12-31-2020, 07:05 AM
No idea. I haven't bought an optical enclosure in 10 years now. The wire you linked will not work. You have more research to do, if you insist on using the SATA drive as an external.
12-31-2020, 07:07 AM
would it be better to buy the external sata drive? I don't know where to buy the optical case
12-31-2020, 07:09 AM
Better? Not really, just different.
Easier? Probably.
Get a non-slim drive, as I mentioned.
12-31-2020, 07:11 AM
this modelis is non-slim?
https://www.kabum.com.br/cgi-local/s...RoCSxAQAvD_BwE
https://www.kabum.com.br/cgi-local/s...i?codigo=65472
model liteon dimensions 140 (W) x 13.5 (H) x 136.3 (L) mm / 5.51 x 0.53 x 5.37 inch
model asus dimensions 19.1 x 7.1 x 18.5 cm
12-31-2020, 08:02 AM
Nope. 8x = slim
doubts
Is Asus AGP-V6800 a good capture card? Aerith Capture, Record, Transfer 2 03-20-2020 07:53 AM
Is Asus EeeBook X205TA good for daily use? tarun_bazooka Digital Devices 4 09-28-2015 05:51 AM
Will my LCD monitor be good enough for video work? (Asus VH242H) rappy Project Planning, Workflows 1 04-24-2012 01:11 PM
DVD+R Burning issue - disc stops burning halfway through staypuftman2004 Copy DVDs, Duplicate, Replicate 3 07-23-2005 05:35 PM
DVD Burning Errors, Cyclic Redundancy Check and burning freezes rmehta2 Copy DVDs, Duplicate, Replicate 7 07-13-2005 12:34 PM
