11-13-2010, 04:16 AM
I came across an interesting plastics industry article from 1998 that was discussing the challenges of producing the quality polycarbonates needed to manufacturer DVDs. While it was obviously a reference to pressed DVD-ROMs, the same general information could just as easily be applied to the yet-undeveloped DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-R DL and DVD+R DL formats.
These were listed as the challenges
Physical Attributes
  • Consistent pellet geometry
  • Minimal fines and chaff
  • Minimal particulates
  • Optical homogeneity
  • Low birefringence
  • Meets impact requirements
Chemical Attributes
  • Low polymerization by-products
  • Minimal additives
  • Narrow molecular weight distribution
  • Low glass transition temperature
Processing Attributes
  • No clouding, sticking, or staining
  • Good color with low yellowness index
  • A robust processing window
  • Fast cycling
  • Consistent viscosity
  • Minimal, uniform static charge on substrate surface
It's a safe assumption that the low-grade pressed and recordable discs we see probably fail at attaining the quality needed to produce quality in-spec blanks and metal DVD-ROMs. These two platters can be just as important as the glues/bonding, the DVD dyes and the silver or gold foils. Bad materials will usually equal a bad disc.
URL: plasticstoday.com/articles/meeting-new-molding-challenges-dvds
For archival purposes, a printout of the article is also attached below as a PDF.
The quality of the disc piojo Blank Media 3 05-25-2009 09:23 PM
Quality Check for me... angelofanimes Encode, Convert for discs 5 07-15-2005 09:52 AM
Best Capture Quality Videopilot Capture, Record, Transfer 5 03-17-2004 09:41 PM
