10-17-2025, 11:55 AM
mr19th mr19th is offline
I have been playing some super8 reels from the late 60's and for the most part they play fine, but I have started coming across some stuttering and/or freezing while playing. I checked the holes on the side of the reels and it looks like they are enlarged/stretched. The parts that play fine and simple squares, but these parts are more of a rectangle than square. They're not huge, but if you look at them, you can tell they are not the same shape as the others. Is that what's causing the stuttering/freezing? How can this be fixed, or can it?
10-17-2025, 12:53 PM
It can be fixed, yes, but not automatically.
I'd need to see a sample clip.
10-17-2025, 01:55 PM
timtape timtape is offline
Movie film can be permanently damaged by running it in a faulty projector at some stage. If you look carefully the sprocket holes in Super 8 are actually rectangles unlike Regular 8 which are squares and larger. But elongation due to projector damage is another thing. Some projectors are better than others at running films with damaged sprocket holes. There are movie film scanners which can successfully run damaged film and without adding to the existing damage.
ATI 600 USB stuttering PAL VHS capture? SeeNoEvil Capture, Record, Transfer 8 06-14-2020 07:20 AM
Video stuttering problem? rocko Capture, Record, Transfer 11 03-19-2017 11:12 PM
AmaRecTV VHS recording stuttering? SixtyTen Capture, Record, Transfer 12 01-18-2016 05:22 PM
Advice on scanners for slides, negative film and 8mm film movies? lordsmurf Photo Processing, Scanning & Printing 3 12-29-2009 11:48 AM
HD video clip has stuttering playback ? manthing Videography: Cameras, TVs and Players 3 02-12-2006 12:19 AM
