Originally Posted by themaster1
Hi LordSmurf i am wondering, as you seem educated about scans, prints etc.. if you happen to know what would be best to print a giant poster something like 2m x 1m . What kind of picture resolution and material should i use to have something decent to hang on the wall in the end.
Thanks for your help
Sharing a conversion from PM, as my responses may help others.
For something that large, you're pretty much forced to take it to a print shop. And then use the best paper you can afford. At the same time, realizing thin stock can be rolled, while you'd want to forever flatten and mount (frame) thicker photo stock.
I've only had to print something that large a few times, always for work-related reasons. 2m x 1m is like a 6x3' print -- as big as I am (well, not that wide!)
At that size, you can even get tapestry prints, made on various cloths (including hybrid plastic cloth). I forget the exact name. It's the same material used for outdoor banners.
In USA, there's only one place I go: The Color Place in Dallas. It's actually a nationally known company for this, amongst the photo and display communities. Their website is horrible, a monkey with a stick made it, so call.
You're in UK, right? I'd guess a comparable type of shop would be in London.
The largest I can print with a $500 pro ink print is about 2' wide, unlimited length (max length of roll, actually). That's what I have for my own prints.
