12-03-2019, 11:06 PM
mark_l mark_l is offline
I'm capturing some old 8 mm tape videos using dvgrab on Linux, saving them to disk as raw video files. I'm playing the tapes with a Sony digital 8 mm camcorder, using a Firewire/PCIe interface. Some of the tapes were recorded on the same camera in Digital8 format, and others were recorded on an analog Sony camcorder (which I no longer have). Most of the latter are in Hi8, but a couple are in Video8 format.
The Digital8 videos play as expected after capture. The Video8 and Hi8 tapes play fine on the camcorder, but when I play the captured .dv file, there is no video or audio. I play them using VLC Player, the video program that comes with Linux, and a Plex Server running on a Synology DS218 NAS. In all those players, there is no video or audio.
Apparently a codec problem, but I don't know what to do about it. When I look at the codec info in VLC, it's the same for the files that play properly and the ones that don't. It says "Codec: DV Video (dv ). I attached a screenshot of the codec info. I tried running the dv files through all the conversion profiles available in VLC, and that didn't help. What must I do differently to capture the video from these analog tapes?
codecs, video capture, video capture codec
Audio popping on home vhs tapes but not retail vhs tapes Egon Capture, Record, Transfer 3 03-09-2019 10:28 AM
Capturing Video8 tapes: resolution, filtering, codecs, audio? johnny7 Capture, Record, Transfer 11 11-07-2015 03:19 PM
Digital8 Camera won't play digital 8 video tapes? DeeSeven Videography: Cameras, TVs and Players 10 07-31-2014 11:04 AM
Quick Tips for capturing video tapes (VHS, VHS-C, Video8, Hi8, DV) lordsmurf General Discussion 0 05-23-2014 01:42 PM
