02-08-2020, 07:55 AM
Warning: BASF tapes from the early 80s tend shed oxide.
At the early stages of tape breakdown, the oxide doesn't literally shed off. What happens is it pre-sheds. Physically, the tape appears to have cracks or spiderwebs in the black metallic surface. On playback, the image has massive dropouts, while the audio may be fine or distorted.
When you start captures, you should always check the tape physically, as you don't want to stick a tape with shed or mold (or similar) into an expensive deck. But pre-shedders tend to appear fine. However, after one play, the oxide breaks down.
After some research, I believe pre-shed is actually accelerated due to cold VCR heads, and in colder climates (or colder times of year). This is almost opposite of the fact that hot weather accelerates tape aging. But both are true.
Besides just heating the room to 70-75 degrees (F, a trick I've recently learned is to preheat the VCR. By that I mean you need to get a commercial tape, and let it run for at least an hour. It will heat the deck internals.
With non-cold room, and preheated deck, the VCR will behave long enough to capture the tape. There's still a high likelihood the tape will be entirely screwed after that one play, so DO NOT MESS UP THE CAPTURE! You may find yourself with a ruined tape, impossible to capture.
And BTW, this is precisely why the advice to "FF/REW all tapes before capture" is ignorant.
We recently had a couple client tapes that had 2-3 minutes of footage destroyed because their tapes were horribly degrading, and this is how it was recovered. Both were the first tapes of the day, and cold heads zapped them. I had a personal tape suffer the same fate last year.
BASF is most common to suffer, but it's on the only brand. And while older 80s tapes mostly suffer, not all 80s tapes have this issue (probably 99% do not), and I've seen it a couple times with 90s tapes as well. But especially be careful of 80s BASF tapes! Much like Panasonic caps, or JVC DDs, it seems we're hitting a point where 80s BASF may also be time bombs.
The following users thank lordsmurf for this useful post: msgohan (02-08-2020)
02-09-2020, 05:59 PM
cbehr91 cbehr91 is offline
Good to know as I have a few BASF tapes from the 90s. Another VHS related timebomb I've experienced not once, but twice recently is the leader tape breaking on Maxell Epitaxial (Hi-Fi and HGX-Gold grades...not junk) tapes from the mid 80s upon rewinding. It's not the end of the world to put a new leader tape on, but it's a troubling trend since I have quite a few of those Maxell tapes.
02-09-2022, 10:42 PM
This is becoming more common, so wanted to bump.
The joys of capturing Hi8 tapes? (Not! Sony tapes suck!) NJRoadfan Capture, Record, Transfer 20 03-27-2022 09:51 AM
Did RAKS use BASF tape? HBB360 General Discussion 0 01-11-2020 06:59 AM
No video/audio from Video8/Hi8 tapes, but Digital8 tapes work? mark_l Capture, Record, Transfer 0 12-03-2019 11:06 PM
Audio popping on home vhs tapes but not retail vhs tapes Egon Capture, Record, Transfer 3 03-09-2019 10:28 AM
Can VHS tapes sit on a shelf too long? Borders on tapes? kpmedia Capture, Record, Transfer 0 03-22-2010 03:54 PM
