06-24-2020, 01:05 PM
null null is offline
Reaching out to see if there are troubleshooting steps I can take, or if this is the best output I can expect.
I have captured some still images of an AVI capture from Virtual Dub to show the issue. The output appears to have some lines, and double/tripling of the image. This seems to most noticeable when there are fast moving objects and/or fast camera movement. I am using Virtual Dub 1.9.11, downloaded from the forums here.
Tape: TGrant Photo S-VHS Demo Tape
VHS: Panasonic AG-1980 (purchased as restored from TGrant)
TBC: TV One 1T-TBC
Capture Device: ATI TV Wonder 600 USB 2.0, using S-Video
Video: 720x480, Huffyuv 2.1.1
I've attached two images that are slow movement scenes, and do not seem to exhibit this issue. The other two are faster movement scenes where the issue is apparent.
06-24-2020, 01:43 PM
traal traal is offline
Those are normal NTSC interlacing artifacts. It looks like the source is film so try the IVTC (inverse telecine) filter in VirtualDub. If it's video then use the deinterlace filter in VirtualDub with one of the "double frame rate" options selected (whichever one keeps the motion fluid as you step through the resulting video frame by frame), or better yet, use the QTGMC filter in Avisynth.
06-24-2020, 02:46 PM
Originally Posted by null View Post
show the issue.
TBC: TV One 1T-TBC
No issues exist, that's just interlacing.
Good gear.
Why?
There is no reason to IVTC or deinterlace yet. Do not deinterlace without a specific reason for doing so!
06-24-2020, 03:26 PM
Why?
Because IVTC restores the original progressive frame rate.
But you're right, "Capture, Record, Transfer" is the wrong forum for this discussion. I wasn't paying attention, so I'm sorry about that!
The following users thank traal for this useful post: lordsmurf (06-24-2020)
Identifying artifacts, fixed with video filters? bilditup1 Restore, Filter, Improve Quality 14 02-23-2018 07:49 AM
Stutter with too much movement, convert Hi8 in VirtualDub? KoenDG Capture, Record, Transfer 1 12-13-2017 09:55 AM
Area around line blurring on movement? koberulz Restore, Filter, Improve Quality 16 03-20-2017 11:01 AM
Avisynth smudging. movement noise? pumapuma Restore, Filter, Improve Quality 12 12-13-2016 10:43 PM
ADC Video Shaper / Visual Processor, what is it? rocko Restore, Filter, Improve Quality 4 06-01-2013 02:30 PM
