03-24-2020, 09:35 AM
Guyz92 Guyz92 is offline
Dear Sir,
I just registered as new member in this forum. I would like to seek for help and assistance regarding suggested instrument or the best way to convert VHS to DVD for a good video quality.
For your information, I had two sets of PAL VCR (consumer version), which were Sony VCR SLV-KH3PS & JVC VCR HR-J781AM, for which both had only composite output, two sets of Panasonic DMR-ES10 for pass-through, and 1 Hauppauge HD PVR. Usually, when I convert VHS, I used this method which is direct from VCR to DVD Recorder. However, I realised that the DVD quality produced is not satisfactory.
I would like to inquire on three issues:
First, can you suggest to me a suitable PAL DVD recorder that can generate good video quality? Is Panasonic DMR-EZ49V a good choice?
Second, if I want to get digital video to be transferred to my computer to be processed later, I’ve been using Hauppauge HD PVR. This unit produced m2ts, ts and mp4. I usually chose progressive output setting on my DVD Recorder. Then, I used a component cable to get the progressive video quality. Is this the best way to get good video quality? Is there any other way that you may suggest?
Third, can you suggest a good PAL VCR that can easily be obtained from e-bay? I would really appreciate your help. Thank you in advance.
03-25-2020, 09:41 AM
What source? LSI based recorders are best for VHS sources.
Capturing to H.264 is not good, MPEG can be good. More details needed.
VCRs: http://www.digitalfaq.com/forum/vide...ing-guide.html
Toshiba (DRW2) DVD Recorder * Good or Bad Recorder Pepeart Capture, Record, Transfer 4 09-20-2006 03:12 AM
