02-15-2021, 11:17 AM
rwades rwades is offline
Trying to capture vhs with a a ucec 2.0 capture device, using virtural dub. (I just plugged in the ucec capture device, and did not load any software that came with it.) I have the following issues:
1. No "video source" options (such as Svideo, composite)
2. Capture Pin, No format optioins, such as NTSC, etc....
3. Capture Filter, there is no video standard option here.
I have obviously missed a big item here. I have some confusion on what file to download codecs and filters in to. I have not picked any VD filters to load from the VD program. I downloaded ffinputdriver and put it in the plugin32 file.
Thanks for your help.
Windows 10
02-15-2021, 10:39 PM
traal traal is offline
Did you install the 32-bit drivers or 64-bit? And is your VirtualDub 32-bit or 64-bit? They need to match.
02-16-2021, 09:39 AM
Thanks for the reply. Since my post, I did find the custom Virtural Dub download provided by this forum. I downloaded it, and I can now convert some video. I still have serveral issues, but will try to work through them before posting again.
Thanks again.
Fix for SET 2/3 error without remote on ES15 Matthew Capture, Record, Transfer 0 07-24-2020 10:13 AM
FS: Aluminum cutting blocks for 8mm-1/8"-1/4"-1/2" tape repair [SOLD] juhok Marketplace 1 12-25-2017 06:35 AM
Found old ADC (DBX) "Video Sharper" processor at thrift store rocko Restore, Filter, Improve Quality 2 04-11-2013 12:10 AM
Found Source of "Wavy Dancing Lines" !! rocko Capture, Record, Transfer 0 02-27-2012 02:03 AM
When some video "help" sites become obnoxious (overzealous Avisynth advice) unclescoob General Discussion 11 11-11-2011 10:24 PM
