02-21-2021, 04:53 AM
MrWa1rus MrWa1rus is offline
Hi!
I have VHS tapes that have been captured (using lagarith lossless codec) in 720x480 which I understand is a standard resolution for DVD players to read. However, my capture device captures small black bars of different sizes on either side of the video that are about a few pixels wide each that I'd like to get rid of before encoding/compressing and burning to disc.
Would I lose information by cropping, resizing back to 720x480, and then encoding into MPEG2 for a DVD? From my understanding, the horizontal lines will not lose resolution by stretching and shrinking but I may be misunderstanding this. I have also read from various sources that you should de-interlace before resizing interlaced video and then re-interlace after the resize. Is this only true if you resize the vertical axis or is it true for both axes?
I'm using virtualdub to capture and edit, and then either handbrake or avidemux to encode to MPEG2 (I'm not sure which of the two is better, but it seems like avidemux will only let me encode to 4:3 rather than the original 720x480 of the avi file).
Any insight would be greatly appreciated, thanks!
02-21-2021, 12:47 PM
http://www.digitalfaq.com/forum/vide...es-aspect.html
http://www.digitalfaq.com/forum/vide...mp4-frame.html
The following users thank latreche34 for this useful post: MrWa1rus (02-21-2021)
crop, deinterlace, mpeg2, resize
What to resize 720x576 PAL to? Should I resize? CZbwoi Restore, Filter, Improve Quality 6 02-26-2021 05:35 PM
How to Properly Crop the Overscan in VirtualDub [GUIDE] kpmedia Edit Video, Audio 32 02-01-2021 10:35 PM
Crop in Virtualdub or Avisynth+? evilt1000 Restore, Filter, Improve Quality 2 06-17-2020 12:05 PM
Properly cropped video, what to encode to? drzapp Edit Video, Audio 4 12-09-2018 08:03 PM
Encode or re-encode, one progran as good as another? cyber-junkie Encode, Convert for discs 1 08-13-2010 05:05 PM
